Old 11-19-2007, 04:34 AM   #16 (permalink)
Roverhound's Avatar
What springs are you running? Are they retained? With long travel shocks in the front you springs will unseat unless your ace is holding the flex back. Then in that case, why the long travel shocks?
It just doesn't matter.
Old 11-19-2007, 02:31 PM   #17 (permalink)
ROVERNIT's Avatar
the springs that Im running are a local manufactured spring both front and rear are retained with the hight the front is now yes the ACE would hold the flex back I have to get the front springs sorted as for the rear the links from the front are the same as the rear for longer length
the ACE is something which needs to be sorted however as per the picture Ian (P76Rangie) showed that has the same link set up as I have but its the front springs that will show concern
why the longer shocks well all our local bilsteins here where going to have 393mm close the 12" 7100 have 400mm close
ROVERNIT is offline   Reply With Quote
Old 11-19-2007, 10:30 PM   #18 (permalink)
what size tyres are those?
1999 Disco2
KyleT is offline   Reply With Quote
Old 11-20-2007, 03:53 AM   #19 (permalink)
ROVERNIT's Avatar
there 32 inch cooper STT which are meant to be my road tyres, plan on getting some 34 inch soon as I sort out what to do with the suspension
Old 11-20-2007, 03:54 AM   #20 (permalink)
ROVERNIT's Avatar
Originally Posted by DiscoAmigo
Why not castor corrected bushes instead of radius arms? Would it be a more legal approach to your problem?
Also, You can use a D1 spring perch in the rear to gain about 10mm in height.
You do not have a winch. Do you plan on getting one? If so, that will adjust ride height in the front too.
Nice truck!
Can you get caster correction bushes? can you recomend any one in the states that do them
Old 11-20-2007, 06:41 AM   #21 (permalink)
DiscoAmigo's Avatar
DAP sells them. Looks like OME sells them too, that's your part of the world
http://www.devon4x4.com/shop.php?mod...cat=7&subcat=7
2001 Discovery II
DiscoAmigo is offline   Reply With Quote
Old 11-20-2007, 01:31 PM   #22 (permalink)
ROVERNIT's Avatar
you would be forgiven for thinking so but we dont get half the OME stuff you guys get
I'll give others ago
Old 11-24-2007, 01:27 AM   #23 (permalink)
ROVERNIT's Avatar
A work in progress a lot of work that is,
My front ACE arms are binding up which needs to be sorted my local 4x4 shop and these are hardcore lads recommend to grind away the seam on the panard rod bracket and weld the inside to make up the strength and remove the piont of where its binding as I still have about 3 inch in the shock unused both front and rear along with about 2 inch in ACE piston a 6 degree Radius are from QT (Jastin) will sort out the front a 5 degree shim and D1 spring seat will sort out the rear next there after are set of flares deeper dish rims and 35 for the track
