If I was you, I would remove the wire completely (hopefully problem goes away), pull trigger from the dome light, run your own power source directly from the battery for all your lights, FUSE IT for the correct amount of draw,and call it a day.
I dont know if your dome light circuit is part of the bcm or not.
2000 Land Rover "Bushranger"
1961 Scout 80 awd
"Every day above ground is a good day"
Al Capone
