Old 08-28-2004, 03:40 PM   #1 (permalink)
TerryS's Avatar
Default Rusty Defender Door Hinges
Has anyone solved the problem of rusting door hinges used on Defenders?
Looking for a DIY solution, rather than simply replacing them. I don't mind the truck getting filthy, I Just hate the site of running rust.
Old 08-28-2004, 07:42 PM   #2 (permalink)
XD90's Avatar
ae you sure its the hinges that are rusting?
on mine its the nuts and bolts that are causing the rust streaks
cure: stainless steel nuts n bolts
XD90 is offline   Reply With Quote
Old 08-29-2004, 06:31 AM   #3 (permalink)
TerryS's Avatar
Default That's Possible
But I changed trhe bolts to stainless quite some time ago, though not the caged nuts. It certainly appears that the rust is coming from the joint of the two hinge halves, so I was thinking it's the hinge itself or the hinge pin.
Old 09-09-2004, 11:16 PM   #4 (permalink)
Bwana's Avatar
Wink Give it a chance to dry out
Move vehicle 2500 miles south west of current location. Clean out rust. Let dry. Stay for rest of life.
Bwana is offline   Reply With Quote
