Old 06-12-2005, 02:33 PM   #1 (permalink)
Wheeler
SCSL's Avatar
Default Strange Question
Is there such a thing as a 9mm bolt? (thread width, not head)
I have an application where an 8mm is too small, a 10 to big. Funny, the bolt I'm replacing screwed into a sample 8x1.25 hole but slid in & out of my application,,,,,,
If not I assume a problem w/ the hold & will have to re-tap it.
Anyone?
Old 06-12-2005, 07:12 PM   #2 (permalink)
Super Moderator
Disco's Avatar
Perhaps it's not metric, but imperial.
Old 06-12-2005, 07:25 PM   #3 (permalink)
Wheeler
SCSL's Avatar
Tried that too,,,,between 2 sizes. Guess the hole's shot & I have to re-tap it
Old 06-13-2005, 06:15 AM   #4 (permalink)
John's Avatar
Hold on, don't try to re-tap it just yet as you might do more harm than good.
There are actually 3 variations of the M9 thread, these are 9 x 1.25 metric course thread and 9 x 0.75, and 9 x 1 metric fine threads.
There are also a number of other thread variants that come very close to what you describe.UNC, UNF, BSF and BSW could all figure in this.
I would suggest you investigate more, unless what you intend to re-tap has little value to you.
John is offline   Reply With Quote
Old 06-13-2005, 06:20 AM   #5 (permalink)
Wheeler
SCSL's Avatar
That's what I needed---A gent from UK to clear up my metric woes. I can't seem to find 9mm anywhere over here but perhaps I just need to look harder, or on-line. Thanks for that info. Now I can search away knowing it's not in vain !
From my experimenting, 9x1.25 course seems to be the one I need.
Thanks again
Old 06-13-2005, 06:24 AM   #6 (permalink)
01001010's Avatar
Gallery: 15
Are you working on a Flux Capacitor for your Rover by any chance???...lol
JC...
1965 Series IIa 109 RHD Dsl - Wilks
www.TerraTrekker.com
Old 06-13-2005, 07:11 AM   #7 (permalink)
Wheeler
SCSL's Avatar
No it's actually a very minor thing,,,,,,,
Old 06-16-2005, 10:52 AM   #8 (permalink)
Wheeler
SCSL's Avatar
Default Clarification of question
OK,,,, I figured out what I need & it's actually a 5/16th grip insert/rib nut. I assumed I needed a 9mm but ass-umed wrong... plus everyone is telling me there are no 9mm fastners available on the general market.
I need 8 inserts but none of the local hardware, plumbing, or auto supply stores carry 'em. Any suggestions for fastners? Websites?
Old 06-16-2005, 12:27 PM   #9 (permalink)
CoachDitka's Avatar
I always found the best supply of nuts/bolts/etc. at my local True Value, believe it or not.
-Coach
CoachDitka is offline   Reply With Quote
