» Sponsors
» Sponsors
Old 05-11-2009, 01:14 PM   #1 (permalink)
RealRitzcracker's Avatar
Default Subwoofer Install
I was wondering if anyone could provide any useful information on install subwoofers in your Land Rover.
Any information you have specific to just subwoofers or specific to a 2004 Land Rover Discovery 2.
The Subs I bought are
Two (2) 12" 800W DVC and are 4 OHM
and the AMP I bought is
1600W Mono Bridgeable MOSFET Amplifier
How would I go about wiring the subs to the amp and the amp to the radio?
Should I purchase an upgraded deck?
Should I also update my other speakers?
What about my battery? (Do I need to upgrade to a Dual Battery Setup?)
Would this be correct?
Cheers!
RealRitzcracker is offline   Reply With Quote
Old 05-12-2009, 01:54 PM   #2 (permalink)
52 Views and 0 Replies
FML
Old 05-12-2009, 04:40 PM   #3 (permalink)
*Aaron*'s Avatar
Do you have any experience with this kinda stuff?
Do you just need to know how to hook the subs up? or Are you looking for information on running power to the amps also?
96 GSX
97 SPYDER GST
02 DISCOVERY
*Aaron* is offline   Reply With Quote
Old 05-12-2009, 08:06 PM   #4 (permalink)
Just remember...if the world didn't suck, we'd all fall off.
Ultraviolet's Avatar
Gallery: 3
Originally Posted by RealRitzcracker View Post
FML
flourometholone?
(un)Happy days, Patrick
Ultraviolet is online now   Reply With Quote
Old 05-14-2009, 05:07 PM   #5 (permalink)
I'm a 100% Newb.
So any info you can provide me with would be awesome.
Old 05-14-2009, 06:17 PM   #6 (permalink)
Gallery: 3
it's pretty simple.. in your engine compartment passenger side centerways on the firewall remove plug and run a hot wire from your battery to your cargo space under the carpet. you can have it run out where your back seats lift up. also in that area there are plenty of bolts witch to attatch your ground for the amp. at the same time your running your hot wire run a remote wire from your ignition, catch it behind your radio. to get the signal easist way without tampering with your radio harness is to open the sub enclouser on the rear cargo door fish two, two pair cables through the rubber hose that leads from the side panel to the door and solder them to the speakers run them through the side panels and under the carpet to where you have the rest of the wires. get a speaker output to line output converter, from there you hook your rca cables to your amp and voila your done. crank your radio bout midways and adjust the pots on the converter till the sound is clear for more or less gain. once that is done turn your radio to your normal listening level and then adjust the gain on the amp until it suits your taste.
Old 05-14-2009, 07:22 PM   #7 (permalink)
*Aaron*'s Avatar
First I will start with running power to the amp. I would highly suggest you go out and by a wiring kit as you will need the large gauge wire, various connectors and inline fuse.
First run the large gauge (2-4) power wire from the pos battery terminal to the inline fuse that should be mounted somewhere in the engine compartment. I choose to mount mine on the passengers side firewall as there is a ton of room there, it is easily hidden, and there is a great point to pass the wire into the cabin.
From the other end of the inline I ran mine through the rubber cover into the cabin. From there run it under the carpet. The disco II carpet is in three sections. Pass the wire under the first two and bring it up under the rear seats where the second and third section over lap. This will make for a clean install and hide all the wires. Connect the pos wire to the 12 volt terminal on your amp.
Now for the ground wire. I ran mine to a bolt under the passenger seat, again it is easily hidden so it made for a clean install. Ran ground to ground terminal on amp.
Now for the signal wires coming from the radio.
Although you dont need a aftermarket radio to hook subs up it will make for a much nicer/clearer sound and make the install much easier. On most aftermarket radios they come with RCA outputs. Alls you need to do is get a good set of audio RCA cables and run them to the amp and plug them into the left and right input terminals on the amp.
The last wire you need to run from the amp is the signal wire that tells the amp to turn on and off with the radio. This is usually a blue wire. Again if you have an aftermarket radio there should already a blue lead for the signal wire.
As for the stock speakers you dont have to upgrade them but like anything else it will make for a much nicer sound. Especially if you use an aftermarket amp to power them also, but that a shit load more work than just hooking up the subs.
96 GSX
97 SPYDER GST
02 DISCOVERY
Old 05-14-2009, 11:52 PM   #8 (permalink)
how do I change this?
mbrummal's Avatar
I hooked my remote turn on to the antenna amplifier on the right window. You have to remove the upper trim, but it isn't that bad. I got power like they said and originally used a line out converter from the rear door speakers.
Mason
'00 DII, $G Front Bumper, Hella 4000s w/HIDs, TW Front DS, "Custom" Exhaust work
(from someone on Bimmerforums)
mbrummal is offline   Reply With Quote
Old 05-16-2009, 03:48 PM   #9 (permalink)
Do you guys have any more pictures?
I'm more of a visual person.
Any pics of the how you wired it under the carpet?
Or of your subs and amp?
THANKS
Old 05-20-2009, 02:05 PM   #10 (permalink)
Range Rover Freedom Fighter
BullDogSix's Avatar
Gallery: 7
Dude...I'm sorry mommy is not here...you have to at least try.
These guys have given you a lot of info....get busy.
SI VIS PACEM, PARA BELLUM
"If you seek peace, prepare for war"
1994 RRC LWB, Cocked, Locked and ready to Rock!
BullDogSix is offline   Reply With Quote
Old 05-20-2009, 02:53 PM   #11 (permalink)
Rover Driver
tcpfl's Avatar
Man... you gotta warn people when you do that. I just spewed diet Dr. Pepper all over my keyboard.
Tom
2006 LR3 SE - Stock except for 255/60/18 General AT2s
2004 Disco II SE - 3" OME HD Springs/Shocks, Borla Cat-Back Exhaust, My Front Shaft Is A Woody, ARB Sidesteps, 255/60/18 General AT2s
2001 Disco II SE - Sold
tcpfl is offline   Reply With Quote
Old 05-31-2009, 07:05 PM   #12 (permalink)
Would these power cables be right?
Newegg.com - Sound Quest SQ1200XB 1200W Power Wiring Kit
Old 06-06-2009, 03:54 AM   #13 (permalink)
Need more info about your amp and subs
The subs. Pair of dual4s. They can be wired at 4 ohms (as per your picture above) or parrallel wired to 1ohm. Parrallel is wiring all the -ves together and vice versa with the +ves.
800w means nothing. Ignore any rating that doesn't have 'rms' after it
Now the amp. Need to know if it's 2ohm or 1ohm stable. Check the specs, should say something like "200rms at 2ohms" or "300rms at 1ohm". Unfortunately I'm guessing it won't do 1600w or anywhere near that.
Please don't follow this advice, you're likely to fry the subs.
rogan is offline   Reply With Quote
Old 06-06-2009, 10:28 AM   #14 (permalink)
The subs are 400W RMS each.
The amp is
1 x 800 Watts RMS @ 4 Ohm
1 x 1000 Watts RMS @ 2 Ohm
Old 06-06-2009, 10:44 AM   #15 (permalink)
mbrummal's Avatar
wire it up just like that picture in your first post so it cannot overpower the subs. It really sucks when that happens.
Mason
Rear Door Speaker install BamaDisco03 Discovery Series II 7 10-09-2008 08:48 AM
Subwoofer Install fiach Discovery Series II 4 08-01-2008 10:18 PM
Info needed: 03/04 Disco Genuine Brush Bar Install Instructions stolenheron Discovery Series II 3 05-26-2008 10:04 PM
Disco II CDL install wimp Discovery Series II 3 11-12-2007 05:24 AM
Fog light install on Chrome bumper part AdrianL Range Rover Classic 0 09-21-2005 12:43 PM
