Old 07-18-2006, 10:11 PM   #1 (permalink)
I love to use my ...
User's Avatar
Default Suspension setup ... need help !
So my air suspension on my 94 Range Rover LWB is now dead, so I want to lift my truck (yeah !!!!) I am looking for a 2" lift, I am using the RR as my daily driver. I've read many things on the forum and on the net about suspension setups for RRC, but I still need your help ! I am between 2½ setups ....
- OME 2" springs and OME shocks. I've read that they are a little bit harsh on the road because of the stiffer springs, so what springs should I get ? I've got no heavy bumper or winch (for now) and there are many applications to choose ... Can anyone tell me how the OME setup feels on a normal road (bumps, potholes, handling, ...) ?
- Big Blue 2" springs and ProComp ES3000 shocks. A much more smooth ride, and more suspension travel in off road condition than the OME setup, that's what I've read. But how smooth is it (like rolling over every corner of the street ...) ? Anybody have a real time experience on the road ?
Also, with 2" Big Blue springs, what is going to be the difference if I use ES3000 shocks or ES9000 shocks ?
Thanks for your help !!!
User is offline   Reply With Quote
Old 07-18-2006, 10:37 PM   #2 (permalink)
Elephantitis penisitis
Well, how much do you load up your truck when you go out on the trail? If you load it up, go with something a little stiffer - I think DAP sells BB's with different spring loads too. I have OME right now but I'd love to give some 3" BB's a try and see how they compare.
Old 07-18-2006, 10:41 PM   #3 (permalink)
Ben
TN-LR3's Avatar
rovertym 2' sprinsg are nice too
1997 D-90 #1345- back to stock
2002 Dodge ram 2500CTD- dd/tow rig
looking to do 1 ton toyota or rover
TN-LR3 is offline   Reply With Quote
Old 07-18-2006, 10:54 PM   #4 (permalink)
Dang...forgot about RTE...yeah dude, go for the RTE!
Old 07-18-2006, 11:11 PM   #5 (permalink)
texasrover's Avatar
I just finished with install of the BBs. I could not be happier. Springs are firm but not harsh... I guess smooth ride is the best description... certianly not mush.
I loaded it down with 500 lbs of corn and with a friend of mine standing on the rear spare to load the feeders... I barely saw any rear squat to it. HUGE difference over the stock springs.
That is not a leak! That is undercarriage rust inhibitor.
98 Discovery
Old 07-19-2006, 12:13 AM   #6 (permalink)
RageRover's Avatar
From experience, my RTE 2" Lift springs and Pro Comp ES9000 shocks from DAP, are in my book, a very good lift and great ride quality, on and off road.
I have the same vehicle as you do, and you will like how much lift you'd get from my setup I have, IMO.
1995 RRC LWB
-RTE 2" Lift Springs
-KMC Front Diff Guard
-T-Case out of an 92' RRC
Old 07-19-2006, 12:16 AM   #7 (permalink)
RageRover's Avatar
Ditto with my RTE springs, I didn't think that it would hold up a crap ton of weight on the rear, I loaded with 500+ lbs., and no squatage.
Plus I just recently towed a 4000 lb. Jeep Wrangler (heavy som' bitch) with tow dolly, and it wasn't squating at all either!
1995 RRC LWB
Old 07-19-2006, 09:03 AM   #8 (permalink)
Ben
TN-LR3's Avatar
I've heard that big blues start to sag pretty early when owning them
Old 07-19-2006, 10:27 AM   #9 (permalink)
Otherwise known as STEVE
That's no longer true- that was the case many years ago with most aftermarket springs. Even the early RTE's had that problem. All the suggestions so far are good. The main difference is the rates and heights- Your LWB probably was originally an air suspended, so it doesn't have the load level unit. What happens then is that you get slightly less lift when comparing the same spring against a RRC that has the load level unit.
The ES3K shock is more of a stock/MD version, the ES9K is quite a bit firmer- but if you go 3" you might need the more aggressive valving to control the stiffer rated springs.
2002 Freelander
2000 DII w/CDL
1967 SIIA 109SW
Former Rovers
2004 Modded "S" Disco, R.I.P.
2004 G4 Disco
2002 Modded Freelander
1995 Modded Disco
1994 D-90 #8
1993 NAS D110
1990 Range Rover County
1973 SIII 88
1972 Range Rover 2 door
Old 07-19-2006, 05:42 PM   #10 (permalink)
User's Avatar
I'm not loading the truck that much while off-roading ... All basic stuff plus light equipement ... But one thing that I did not mention, I must tow my 2400 lbs race car (+ trailer) sometimes .... Is that going to make a difference on the road for the springs ?
What advantages does the RTE springs have over the BB ? Or they are almost the same ... ?
As for the shocks, I'll probably go with the 9000 ! But I still need to choose the rate of the springs ....
Thanks !
BTW RageRover, I think this setup gave you a little bit more than a 2" lift ... no ?!?!?! What spring rate do you have ?
Old 07-19-2006, 10:10 PM   #11 (permalink)
For a sub-3" lift, OME is the best in my book. Above 3", RTE takes the cake.
War Eagle!!!
Ares is offline   Reply With Quote
Old 07-19-2006, 10:20 PM   #12 (permalink)
Rocky Mountain High
Funrover's Avatar
I have OME and love them....... he rides is great IMHO!!!! But I have also riden in a rover with RTE and was very impressed...My friend has a Disco with the BB's....it has been great so far, but the ride seems soft to me!
Old 07-20-2006, 02:01 AM   #13 (permalink)
RageRover's Avatar
I managed to haul a 4000 lb. Jeep YJ a good 130 some miles and had no sagging what so ever, then again the weight was distributed over a dolly.
The truck was perfectly capable of handling the weight though.
1995 RRC LWB
