Old 02-18-2005, 10:16 PM   #1 (permalink)
Default suspensions and springs
I want to lift my 97 Discovery SE 3 inches and unfortunately ome does not make a 3 inch lift, so I come here to hear all of your opinions on Rovertym's 3'' 330lbs-360lbs springs? Would putting in spacers with the OME springs work instead and would it be a wise decision? Isnt it just easier to put in place a 3'' spring? What are your opinions on Rancho's springs? Also on top of the 3'' suspension lift, would it be too much to add a 2'' body lift? I already have a safety devices roof rack and I'm concerned that the body lift would make the center of gravity too high of an already high vehicle. I know that someone suggested taking out the quarter pannel not long ago in a similar question but would that work with a tire that is 265x85x16? What are your opinions on the Old Man Emu LTR suspesions? I only ask because just recently I took my stock truck to hollister and realized how much easier it would be with a lift, larger tires and not to mention LOCKERS, but I have made my decision on the lockers already. Any suggestions would be greatly appreciated.
RickyRover is offline   Reply With Quote
Old 02-19-2005, 02:34 PM   #2 (permalink)
Banned
RTE has some good stuff. They have had their share of problems in the begining, but the new springs are awesome.
Adding a 2" body lift to the 3" springs is ok. You should not have any problems with that. You will, however, get mixed reviews on the body lift, usalley from people who have never had one, so take it with a grain of salt...
OME shocks are ok, but the Bilistens, I think, are better. The bills (7000 series) are completely rebuildable, and is a quality product. If it were my money, I would spend the extra few bucks on the bills...
OME makes a good spring. In fact, I have a set of HD rears on my truck. But, the RTE stuff is very nice, and if I were to replace them, I would use RTE's.
Of course, with a 3"+ lift, you may run into drive line vibes....I would just call Steve at RTE and get a quote on the whole deal ( brake lines, drive shafts, f/r links, retainers/cones, etc...). If you get everything you need from Steve, I'm sure you can get a package deal.
Hank is offline   Reply With Quote
Old 02-19-2005, 10:58 PM   #3 (permalink)
Thanks for the info, I greatly appreciate it. Any others who also wish to share are welcomed as well.
Old 02-20-2005, 07:01 AM   #4 (permalink)
yo mama
Jonesy's Avatar
Ricky....a cuple of things I have heard about Rovertyme stuff...
  1. Their products are well manufactured
  2. They stand behind their products with 100% support
  3. They use their products...check out the Rovertyme Disco on their website
  4. They support the Land Rover community
  5. They have a great following of VERY happy buyers
Just my .02c.....I would recommend any company that you could say the above for these days!
ONE LIFE - LIVE IT
Jonesy is offline   Reply With Quote
Old 02-20-2005, 08:25 PM   #5 (permalink)
Thanks Jonesy on the info. Does anybody know anything about Rancho springs/shocks?
Old 02-20-2005, 08:47 PM   #6 (permalink)
Banned
Never heard of a Rancho Spring to fit a Rover....There shocks are good, but not the cats a**.....
Old 02-20-2005, 11:10 PM   #7 (permalink)
Kristopher's Avatar
Thumbs up Rovertym gets my nod
I have recently installed the RTE 2" lift to my RR, a '95 Classic. I love it. I took the front and rear swaybars off for better articulation, so it likes to sway a bit, no bother though. The combination of the RTE H/D springs and Rancho 9000x shocks has been a big surprise. I was hearing that the Rancho's are rough riders. The 9000x's are adjustable, I have them set at their mid settings and I am really happy. I went with the 2" vs. the 3" because of the aforementioned driveline issues. I figure that if later I want to go up I can, since I have done the basics(for the most part).
What I have:
2" H/D springs front and rear
coil conversion kit
lower spring retainers in the rear
Rancho 9000x shocks
Dislocation cones for the rear
Radius arms for the rear
Rear brake lines
Track rod and drag links w/new tie rod ends
Steering damper relocation
I am now running a 15" wheel with a 31x10.5-15 tire(Firestone Destination M/T) with ZERO clearance issues. I really like the tire too.
Very happy customer
--Kris
Kristopher is offline   Reply With Quote
Old 02-21-2005, 12:58 AM   #8 (permalink)
Thanks for all your input, I will take them into consideration on my decision.
Old 02-22-2005, 01:50 AM   #9 (permalink)
Thank you all very much for your inputs, however I was wondering about the the brake line extensions some of you have stated. Its that a hard job? Would the ABS need to be extended as well?
Old 02-22-2005, 10:36 AM   #10 (permalink)
Kristopher's Avatar
Default Abs
I was worried too about the length of the lines for the ABS. I installed all of the suspension pieces and the brake lines and then let the axle go to full droop, "nada problem!". The good thing is that the RTE guys are informed and have worked through most of this stuff, ask away and Steve will help you out.
--Kris
Old 02-22-2005, 10:48 AM   #11 (permalink)
Thanks
Old 02-24-2005, 03:38 PM   #12 (permalink)
Kristopher's Avatar
Default RTE 2" on a 95 Classic (max Articulation)
Here are a few pics to give you an idea:
Old 02-24-2005, 03:50 PM   #13 (permalink)
Kristopher's Avatar
More:
Old 02-24-2005, 03:50 PM   #14 (permalink)
Kristopher's Avatar
more:
Old 02-24-2005, 05:07 PM   #15 (permalink)
That's a nice ride thereKristopher, but I have a couple of questions. Is it possible to run with 33'' or 34'' tires with your set up? Do your tires tuck in easily when they start to articulate? Also what brand of steering relocation unit are you using?
