Roads?...Where we're going, we don't need roads...
![]() Join Date: Oct 2005
Alright, my internet has been down since thursday.....so im a bit late in posting this....anyhow, I installed my vigg designs hood blackout from the group buy.
It arrived thursday, and I ordered it the friday before that I believe......since it came from accross the country the shipping took as long as it should have. Supposedly it came with instructions on how to put it on, but I looked all over and couldnt find them. Since I didnt have the internet I called Vigg Designs and was told to do this: First super clean the hood, (then I let it dry). Peel off the vinyl blackout from the paper backing, DO NOT GET THE BACKING WET!....it will destory the blackout. You then have to soak the hood with slightly soapy water and place the decal on the hood. The wet water allows you to move it around to adjust it. At this point I had to use a razor to cut around the washer jet heads....my only dissapointment with the product was that they were not pre-cut.....I did the best job I could, cutting it almost exact, I intend to use a couple drops of matt black fabric paint to remove all white around the edge of the jet heads. It came with a spreader tool, which you use to push out the water from underneath the vinyl.....I spread it out from the center out to be consistant so as not to created pockets of air in various places. The blackout is also too long....by about 4in.....when placed correctly at the front it hangs back over the windshield wipers. I cut that short and then folded it over.....I had to wait till everything was dry before folding it over and it sticking. Because it was getting dark and the temp was going to drop below freezing, I used a hair dryer and let it blow a warm breeze on the windshield rain gutter to speed up the drying process. Here are some final pics.....I like it very much, I would just suggest that all future blackouts come with precut washer jet head holes....it was difficult to cut them while the blackout was sliding around and wet.......along with not being flat, and it would have been difficult to cut them before I stuck the vinyl on and got it lined up. ![]() ![]() ![]() |
![]() Join Date: Dec 2005
Looks good!
Gives it a more off-road look of a rugged hood! I wonder if they make that blackout for a RRC hood.![]() Looks really good though, I've seen these designs on other Disco's as well, and I like em'. ![]()
Pat Albaugh, Midwest Moderator "Diffage" -the point at which the truck's differential makes contact with the ground. http://www.cardomain.com/id/RageRover42Visit my RRC and others here!(updated as of September 15, 2006) 1995 RRC LWB -LT265/75R16 Pathfinder All Terrains -RTE 2" Lift Springs -Pro Comp ES9000 Shocks (from DAP Enterprises) -KMC Front Diff Guard -4 Desert Fox 55 watt Lighting -Radio Shack CB Radio (never know when signal fails on a cell phone) -2 Halogen Super Sport 100 watt forward lights -Brush Gaurd, meant for a Jeep Grand Cherokee, now fitted to the RRC -Lowe's Special "Homemade" Snorkel -T-Case out of an 92' RRC |
#3 (permalink) | |
Thanks, they do make one for the RRC hood..... If you are interested you should talk to ryan muller to see if he can get you the group buy discount......otherwise wait till next time or get it from someone else. |
Looks good to me! Yeah if I really want one, I'll give Muller a PM or something.
Otherwise known as STEVE
You're really supposed to wait to cut the washer jet holes after it dries- then it's easy. If they pre-cut those, it would make lining it up WAY harder as vinyl stretches when you squeegie it.
Woah, when did you get the Lightforces??? Looks good man, After i repaint mine, the one i bought from Chris Hyde a while back with llesra will go on
JC... 1996 Discovery SE - The Blue Marlin - gone =( 1965 Series IIa 109 RHD Dsl - Wilks www.TerraTrekker.com
#8 (permalink) | |
#9 (permalink) | |
lol, chris hyde with the everything white DII......dude that guy is nuts Anyhow, I bought them from cerrones auto on lrrforums.com, tony personally delivered them on the hollister trip. I intend to replace the bulbs with something a bit higher wattage. They are 100w "longlife"...supposedly = to 75w or something? ...either way I dont have a choice. To make a short story even shorter, while removing the housings, a mear bump knocked the bulbs off the prongs that they plug in with.....pretty weak soddering. There is a thread that was posted this week on the lights.....I had comparison pics.Ragerover: Check out this thread-http://www.landroversonly.com/forums/showthread.php?t=7819 .. hurry up though, the deal ends Tuesday! Last edited by rmuller : 02-25-2006 at 08:42 PM. |
#10 (permalink) |
Looks good!
Yeah, you want to get the blackout on, and let squeege everything out before you start cutting.. your cuts for the washer nozzles dont have to be perfect, just cut it a little bit less than the size of it, then when you put the nozzle on it should wrap under. Like Steve said, if we were to precut the nozzles it would make it impossible to line it up. Oh wait, did you remember to remove the washer jets before installing it?! They just pop out (be a little bit careful as they are brittle).. you just unclip them install the blackout, get it aligned and once its on perfect, use an X-Acto to cut the holes out.
#11 (permalink) | |
Anyhow, you cant even tell from the pics, it really is that close.....they are at most 1mm of white showing at some parts....not even all the way around. Jeez......I guess I can do it right in five years. |
#12 (permalink) |
Haha, sorry about that, there should have been instructions included.. we do have them printed out. I'll put good instructions online. Whoever answered the phone may have thought you had a DI, which has no nozzles.
#13 (permalink) |
I stated DII for sure......either way, it turned out ok. The reason I called is because my internet has been down since thursday.....the box for sure didnt contain instructions though; I emptied the contence on the middle of a floor in an empty room.....I even tore apart the box and shipping packet-label to see if it was wedged inside.
I should have thought of it.....about the nozzles......in this case I take back what I said about the product being bad in any way....though I do wish I was given better instructions. |
#15 (permalink) | |
How are the Islands? I have seen a couple of silver Discos with the decal on the hood and they really look good. I have thought about doing it on my silver DII, think it would look good with my black bumper. Mike |
| Thread Tools | |
| Display Modes | |
