So I've got the Winch commin in on Monday. Can't wait to get that baby installed. I'll have it hooked up to my ONE battery temporarily. I've got an Optima Red Top (850CCA). The Minimum requirement is 650CCA. I'hope to be ok with this set up for about 3 weeks until I come up with a way to neatly pack a yellow top at the rear of the truck and NEATLY run the wires to the front. As always, I'll being doin a write up / picture documentary.
I still owe you guys the one for the Mantec and the Initial Bumper Install (nothing complicated) ![]()
JC... 1996 Discovery SE - The Blue Marlin - gone =( 1965 Series IIa 109 RHD 2.25L Dsl - Wilks 1965 Series IIa 88' LHD 2.25L Petrol - Fionna |
Ian Matthews
I have a 9.5XP. The main thing you have to worry about is that they are wider than any other winch and very few production winch or bull bars will take them. But they are an excellent winch. With your battery it is not so much the CCAs (they are important though) it is how many AH's they have. The AH (amp hours) is basically how much energy they hold, where CCAs is how quick they can get that energy out. Most of the Optimas are only around 50AH, which is not that much. So be careful how long you winch for as I have flattened mine to a state that the engine stopped due to no power to run the electrics. Also see if you can rig up a fast idle for when you winch to get the alternator pumping out as much power as possible. I run mine at around 1,500 RPM.
Ian |
Ian, THANK you VERY much for that bit of information. Very Helpful indeed. I will get a second batter (Yellow-top) installed sooner than anticipated I guess.
So I'm looking at the Winching Techniques guide on the site...
http://www.warn.com/corporate/images...US.readers.pdf Anyone notice anything familiar in the illustrations besides the winch?
#7 (permalink) | |
4x4 Adventure Gear
JC, congrats on the purchase, the fairlead is on its way!
John C 1996 DI - 3" AG lift 1995 DI - Scorpion Racing Extreme Kit 1991 RR - parting out (few parts left) 1990 Kawasaki KL650B Tengai 1989 Kawasaki KLR650 |
#8 (permalink) | |
#9 (permalink) |
Optima mentions that you can not mix a Red Top with a Blue or Yellow or any other combination do to difference in discharge and charge rate they even mention not to mix 2 like batteries of different ages. You might want to get to matching batterys.
I had to deal with this a couple of years ago when I went to duals. Mike |
#10 (permalink) |
rovering??
dude thats great i wanna se the pics soon.. but you will not get get it in on monday,monday is a holiday... so ull get it in on tue....
-Nikunj 1993 Range Rover Classic LWB 1995 VW JETTA
#11 (permalink) |
Ian Matthews
An extra point to note is that even if the winch will fit in, the slit for the cable may not line up with the winch as the motor is large, but not the gearbox. Therefore the winch drum will tend to sit to one side.
Ian |
#12 (permalink) |
Otherwise known as STEVE
Nice winch! Make sure to break it in before hitting the trail, as with ANY winch.
The only way to mix dissimilar batteries is with certain kinds of isolator/managers. Otherwise, use two batteries of the same type and age. I highly recommend NOT using an optima. Their failure rate recently is staggering.
#13 (permalink) |
What is another option for batteries? I've always used Optimas.
Nikunj...thank you for bringing that to my attention! Normally when I order from my shipper up in PA i have stuff in Two Days. Since I open on Monday, I forgot about that little tid bit.
#14 (permalink) |
Check out this thread:
http://discoweb.org/forums/showthread.php?t=17009
#15 (permalink) |
Just confirmed with my shipper...WILL be receiving winch and snatch block on Monday!..WEEEEEE
