Links
Go Back   Land Rovers Only - Land Rover Forum > Land Rovers Only Classifieds > Land Rover Parts and Vehicles Wanted
Old 02-20-2008, 06:57 AM   #1 (permalink)
Default 2000 DII Plug Wire used OK
I have a post in the DII section about 7 of 8 wires being new and one that was damaged. I bought them as a parts lot off ebay very cheap so I can't return them.
I was looking for how to get just the one wire. But if anyone kept an old set of wires that isn't cooked or just replaced them as an upgrade- would you be interested in selling or donating the used set cheap or even just the one wire.
The ones I have are 8mm STI wires. I can't recall the cyl # but its the front (closest to the radiator) on the pas-side, so its one of the two long wires that I need.
I'll need to do some major work and most likely replace all of them when I do that but I'd like to get that old one off there with a decent wire that will be good for 10k miles or so.
Thanks for reading and let me know what you've got.
stb616 is offline   Reply With Quote
Spark plug wire install Portugal_Disco Discovery Series II 3 07-10-2006 09:58 AM
1999 4.6 needs some work; fix or sell? Spring Range Rover P38, Mk III and Range Rover Sport 17 01-29-2006 01:18 PM
I've fix it, here are the result $200 v $0 sidawson Discovery Series I 0 06-07-2005 10:46 AM
oil around plug wire GentrysRover Discovery Series I 3 02-20-2005 08:01 AM
Problem with the window wipers JP-NORWAY Defender 2 09-02-2004 09:06 PM
