Go Back   Land Rovers Only - Land Rover Forum > Land Rovers Only Classifieds > Land Rover Parts and Vehicles Wanted
Old 09-28-2007, 12:55 PM   #1 (permalink)
drewclare25's Avatar
Default engine replacement
im posting for my buddy who has an LR disco 4.0 v8i, wants to do a swap because its gone to hell, blown, warped, the works. He wants a straight up swap if possible or for an upgrade, what all would have to be done as far as matching things up, and what are some options?
thanks guys
Best 4x4xFar
97 Green D1
3" BB springs
pro comp es9000 shocks
32x11.50 BFG Mud Terrains
15" american racing steel wheels
flowmaster 40 series dual pipes
mantec snorkel
drewclare25 is offline   Reply With Quote
Old 09-28-2007, 02:32 PM   #2 (permalink)
Rebuilding Rover
ArmyRover's Avatar
4.6 would be a pretty straight swap and pick up some nice power
http://snhlr.org/
91 Range Rover Classic
90 RRC Parts truck
94 Saab gas mileage beater
Old 09-28-2007, 05:00 PM   #3 (permalink)
yeah he said he'd be down for a 4.6...what has to be done as far as transfer case adapters and stuff like that?
Best 4x4xFar
97 Green D1
3" BB springs
mantec snorkel
Old 09-28-2007, 05:32 PM   #4 (permalink)
Rebuilding Rover
ArmyRover's Avatar
From what I have read nothing that I can think of just make sure you get the ecu
I'm sure some of the more educated members on this swap will speak up shortly.
Also check out east coast rovers they do alot of these swaps and have some good photo run throughs of the swap.
http://eastcoastrover.com/
http://snhlr.org/
90 RRC Parts truck
Old 09-29-2007, 06:47 AM   #5 (permalink)
Giver of Last Rights to Fallen Rovers
Default 4.0 motor
To put a 4.6 into a disco you would have to use your old timing cover but other than that it's not a huge deal. I don't have a 4.6 right now but i do have a several 4.0's Have him give me a call if he's interested.
thanks
Marty
270 576 7922
Drillbit is offline   Reply With Quote
Old 10-01-2007, 01:26 PM   #6 (permalink)
what options do you have for a 4.0 mileage and pricewise?
Best 4x4xFar
97 Green D1
3" BB springs
mantec snorkel
Old 10-11-2007, 03:50 PM   #7 (permalink)
sent a pm, did you get it?
270 576 7922
Old 05-03-2008, 02:14 PM   #8 (permalink)
If you want a 4.0 I've got one but may need some work once I strip it down I'll tell you
xd97disco is offline   Reply With Quote
Old 05-04-2008, 11:52 AM   #9 (permalink)
XtremeMarine's Avatar
I've done the 4.6 swap, and it's rather easy. You don't even need the ecu. The truck will run with the 4.0 ecu; then you just bring it to your local dealer, and have them reflash it, to let it know it's running a 4.6 instead. Their are no adapters involved. Same transmission, same t-case, and same motor mounts. I got a gems 4.6 out of a RR, to save money, then just swapped on my BOSCH bits, which were all good. Found a lower mileage one for a better price. But to be safe, just swap gems to gems, and bosch to bosch. Then the only part from your motor that you'll need is the oil timing cover.
Originally Posted by Elemental
Some guys play hard to get, I play hard to want.
