What do you consider cheap? Where are you located? These things weigh a ton and will not be cheap to ship. When you say cheap what exactly do you mean? I have one out of a D1 that will fit a '95. It's not perfect but until you give us an idea of what you're really looking for I
First, try adding your location to your profile. I'm in CT, if you're in WA it's likely the shipping will kill a deal but if you're local I may have what you need.
Second, give us an idea of what the problem is and what you really are looking to accomplish, ie. do you just have a leak at the pitman arm that is an issue or has the entire box been trashed?
Third, as I asked above, what is a cheap price? Is approximately $250 cheap? If so give Meridian in southern CA a call. If $50 bucks is cheap I might have what you need but see the above proviso with regard to location.
In the end, a little more info might go a long way toward help us in your quest for a steering box "for a cheap price."
