Go Back   Land Rovers Only - Land Rover Forum > Land Rovers Only General Forums > Show it off
Old 05-08-2007, 11:07 AM   #16 (permalink)
Thor's Avatar
Originally Posted by BIG ROVER
I about pull a nut mussle everytime I have to lift the spare onto the rack.
gotta work that muscle out a little more!
I've got a 1/2 rack, and a Defender stock spare mount that sandwiches the support bars of the rack to hold the spare. Should be fun to align those studs!
I'm having a ladder fabbed up from the rack to the bumper to help in the spare tire on/off process!
Todd
Carpe Rangius Roverum
Old 05-08-2007, 02:40 PM   #17 (permalink)
Yoohoo.. Clown is going to eat your soul!
chrisvonc's Avatar
Specs: 3 inch RTE HD springs, A mix of OME and Rancho shocks (soon to be all Rancho), modified spring mounts (+1 inch), safari gard 3 link, RTE rear links, RTE rear A arm extension, Tom woods dual cardon rear drive shaft, modified front driveshaft with spicer u joint, RTE 2 inch bodylift, 24 spline axle conversion, GCR 15x8 wheels, 33x12.5 super swamper tsl radials, Terrain Master winch bumper, warn x8000i, Equipe skid plate, Equipe steering stabilizer relocation kit with track bar, Equipe diff guards, Surco roof rack with Hi lift and shovel/axe carrier, Hella FF lights on rack, Bosch 9 inch driving lights on bumper, Modified disco safari snorkle (fully funtional), custom borla exhaust. Only other thing is my front Detroit trutrac which I am having rebuilt so it is not currently on the truck.
I assume you put a locker in the rear?
What shape is the inside?
Let see some pics under that baby if you get a chance.
Chris von C.
Sick of how slow LRO has become with all the ad's? Rage Against The Banners!!
If you use Firefox, install the add-on AdBlock Plus. All ads gone and the site loads like greased lightning again.
Originally Posted by roverich: Girls that drive rovers are hot, girls that wrench on them are roverlicious!!!!
chrisvonc is offline   Reply With Quote
Old 05-08-2007, 02:48 PM   #18 (permalink)
chrisvonc's Avatar
Hey.. how does the hood open with that Disco snorkel?
Chris von C.
Old 05-08-2007, 04:00 PM   #19 (permalink)
Banned
Roverzuce is offline   Reply With Quote
Old 05-08-2007, 07:01 PM   #20 (permalink)
BIG ROVER's Avatar
The snorkle has been cut out from the backside. A bolt with a knob goes through the side of the snorkle and threads into a nut welded to the backside of the hood. A flex pipe goes through the snorkle to the top. To open the hood you just turn the knob and remove the bolt. Pretty easy. Looks better IMO than a home made pvc snorkle and is just as functional.
Stock rear diff for now. I may do another trutrac but no Locker in the rear yet untill I go to heavy duty axles. The 24 spline was a step up from the 10 but still not strong enough for a locker. As far as the inside goes, its in good shape. Winchester grey, removed carpet with black bedliner painted floors.
Dustin
1992 Range Rover, RTE Suspension, RTE body lift, Safari Gard 3 link, GCR Wheels, Super Swampers, Warn 8000i, and more.
BIG ROVER is offline   Reply With Quote
Old 05-08-2007, 07:13 PM   #21 (permalink)
BIG ROVER's Avatar
Only underside pic I currently have this one looking at my rear driveshaft. Nothing to special going on.
Dustin
Old 05-08-2007, 07:28 PM   #22 (permalink)
fivespddisco's Avatar
Gallery: 10
great give me a call or pm me your #
Check out WWW.Lucky8LLc.com 716-898-8153 Justin
fivespddisco is offline   Reply With Quote
Old 05-08-2007, 11:00 PM   #23 (permalink)
chrisvonc's Avatar
Ahhh ok so the feeder tube goes through the section by the windshield as other snorkels would and the front leader part of the plastic body is not used.
Gotcha about the knob. Now that you described it, I think I can make it out in the pics. Interesting work around.
Chris von C.
Old 05-08-2007, 11:57 PM   #24 (permalink)
butthead's Avatar
nice rig......I thought of modifying mine into something like yours.....but at the moment it look like this.....what do you guys think?....maintain this look or modify it?.....
butthead is offline   Reply With Quote
Old 05-09-2007, 05:00 PM   #25 (permalink)
Gallery: 10
what do you want to do with it?
Old 05-09-2007, 11:30 PM   #26 (permalink)
butthead's Avatar
remove plastic bumpers, replace with metal winch bumpers, add winch, maybe add about 2" lift, metal jackable side steps, offset wheels with MT tyres, spotlights, lights bar on roof, protection plates for axle, tank, steering....
at the moment already having about 2" lift as I'm using King Springs and Koni shocks....but total will have 4" after mod....but afraid that I will lose stability due to high CG while driving on the road......
Old 05-09-2007, 11:39 PM   #27 (permalink)
Choqiees's Avatar
maintain that look, and use it to cruise around town.
2002 Discovery II SE
1999 Range Rover P38 HSE
Old 05-10-2007, 07:33 PM   #28 (permalink)
butthead's Avatar
I thought of that too.....no point spending extra to change what is nice already......maybe I should do any modification on a rundown unit than a perfect one.....thanks...
Old 05-15-2007, 01:51 PM   #29 (permalink)
www.bonkas4x4wales.com
tony akv's Avatar
Thumbs up
looking nice
tony akv is offline   Reply With Quote
