Just installed a Chevy 350 in my Discovery!! - Page 2 - Land Rover Forums : Land Rover and Range Rover Forum
 3Likes
post #16 of 166 (permalink) Old 08-27-2009, 07:23 AM Thread Starter
Quoted: 0 Post(s)
I have an LS1 sitting on the ground but decided to go with the Tuned Port because I already had the computer and painless wiring that came out of my old hot rod. Its probably going to be way to much...but it will be fun.
sturg38 is offline
post #17 of 166 (permalink) Old 08-27-2009, 12:55 PM
Quoted: 0 Post(s)
i've seen this done before in a DI, except it was a vortec 4.3. there was a ridiculous amount of room left in the engine bay after wards. i believe he just sent the bolt hole measurements in to an adapter company and they had it made for him for a couple hundred bucks.
michaels is offline
post #18 of 166 (permalink) Old 08-27-2009, 02:21 PM
got mud?
Jupiter Rover's Avatar
Quoted: 0 Post(s)
Do you even know what a 350 is?
I'll give you a clue, it isn't a tiny S10 engine.
Pete
2003 DII CDL equipped
33" Destination M/Ts
Jupiter Rover is offline
post #19 of 166 (permalink) Old 08-27-2009, 03:05 PM
OldnDirty's Avatar
Quoted: 0 Post(s)
Nope, It's a little tiny small block Chevy. TPIs make good torque though. Hopefully the Rover tranny will hold up to the 350. If it's stock (the motor), it's only good for about 300-350 lb./ft. I think the 350 TPI IROCs were reated at 240HP.
Never follow stupid people to stupid places to do stupid things...
OldnDirty is offline
post #20 of 166 (permalink) Old 08-27-2009, 06:28 PM
Quoted: 0 Post(s)
uhh yes i know that. i was saying i've seen a chevy engine go in a DI before. a wortec 4.3 is a small block V* with two cynlinders cut off. the rest of the engine is the exact same.
michaels is offline
post #21 of 166 (permalink) Old 08-27-2009, 06:51 PM
OldnDirty's Avatar
Quoted: 0 Post(s)
"almost" exactly the same
post #22 of 166 (permalink) Old 08-27-2009, 07:03 PM
Quoted: 0 Post(s)
close enough. i had one in my old truck.
michaels is offline
post #23 of 166 (permalink) Old 08-27-2009, 09:09 PM
Quoted: 0 Post(s)
Originally Posted by Prodigy999 View Post
I'm still waiting to see a Land Rover with an LS1...
LS1 is god!!! That'll be my project once this ticking motor goes. Either a 6.0L LQ9 or an 6.2L L92.
2003 Discovery S
flipped
1995 RRC LWB 25 Ann. Ed.: Full 5" RTE Suspension Lift, Front and rear RTE Bumpers, Roof Rack, 36" Super Swamper TSL on steelies, Gears, Axles, Lockers, RE 12,000.
LebanonOffRoad.com - Roco4x4.com -
LebaneseShowoff is offline
post #24 of 166 (permalink) Old 08-27-2009, 09:16 PM
mbrummal's Avatar
Quoted: 0 Post(s)
Those aren't LS1s.
This site sucks balls.
mbrummal is offline
post #25 of 166 (permalink) Old 08-27-2009, 09:27 PM
got mud?
Quoted: 0 Post(s)
People need to learn their engines. Or at least the basic stuff.....
Pete
post #26 of 166 (permalink) Old 08-27-2009, 09:56 PM
House Trained
Prodigy999's Avatar
Quoted: 0 Post(s)
The TPI motor you have is probably a good choice anyways because it won't make the axle breaking power that the LS1 would. Either way good stuff...
03 Disco diff locked rig
04 Disco stocker
Prodigy999 is offline
post #27 of 166 (permalink) Old 08-27-2009, 10:05 PM
mbrummal's Avatar
Quoted: 0 Post(s)
x2
mbrummal is offline
post #28 of 166 (permalink) Old 08-28-2009, 11:37 AM
Quoted: 0 Post(s)
Originally Posted by mbrummal View Post
Those aren't LS1s.
An LQ9 is the same design as the LS1, except iron block and bigger displacement. Aluminum blocks fail in truck. I had a cam and bolt-on 98 LS1 that ran 11.4 in the 1/4 mile, i beileve i know what an LS1 is. People put 408 LQ9 strokers on F-bodies because they can take the abuse an aluminum block can't.
2003 Discovery S
flipped
post #29 of 166 (permalink) Old 08-28-2009, 11:38 AM
Quoted: 0 Post(s)
L98's make a lot of torque.
2003 Discovery S
flipped
post #30 of 166 (permalink) Old 08-28-2009, 12:18 PM
mbrummal's Avatar
Quoted: 0 Post(s)
I was just saying it isn't an LS1. an LS1 is an LS1. an LQ9 is an LQ9.
They are different. The bores are different. The stroke is the same. Cams are different-- LS1 has a gun-drilled cam, the LQ9 has a billet. Different rocker arms. The compression ratio is different as well. Sure, the LQ4 and LQ9 are based off of the rest of the Gen III small blocks (the first of which was the LS1), but they are different
And WTF is this BS about aluminum blocks not taking abuse as well as cast iron? So, are you saying the LS9 would be better with a cast iron block because aluminum isn't strong enough?
It is the most powerful engine from the factory GM has ever made. That is a testament to aluminum's durability.
Well, that and the fact that GM is moving to all aluminum blocks across the board.
mbrummal is offline
  Land Rover Forums : Land Rover and Range Rover Forum > Land Rovers Only General Forums > Show it off
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
User Tag List
Linear Mode Linear Mode
1997 Discovery XD Serg Land Rover Vehicles 46 06-25-2010 09:35 PM
2002 Discovery Parts and Hannibal Equipment for sale nathansharkey Land Rover Parts and Accessories 11 02-06-2009 01:51 PM
Installed HID headlight Kit on Discovery 1 Adam in NYC USA Accessories 35 04-09-2007 12:33 PM
1995 Discovery 2.5 300 Tdi Offroader freelanderman Land Rover Vehicles 4 05-12-2006 08:44 AM
Land Rover Discovery 3 (LR3) Launched in Kenya Serg General Land Rover Discussion 1 11-20-2005 10:56 AM
You may post new threads
You may post replies
