Old 07-21-2008, 08:47 PM   #1 (permalink)
Default 19" wheels on 2000 4.6?
is there any reason i could not put 19" wheels from a 2004 range rover on a 2000 range rover which currently has 18" wheels? both wheel sets are oem land rover. thnx.
wilderflouge is offline   Reply With Quote
Old 07-22-2008, 06:04 AM   #2 (permalink)
got mud?
Jupiter Rover's Avatar
it depends on the lug pattern.. if the lug pattern is the same then Yes they will fit.
DII
-- Pete
Old 09-06-2008, 08:02 AM   #3 (permalink)
Yes, they will fit but you will need different lug nuts and I strongly recommend the wheel rings as the newer wheels are hub centric.
rokrawlr is offline   Reply With Quote
LR2, 19" range rover sport wheels and more tonheko Freelander / LR2 0 07-03-2008 12:44 PM
New 19" OEM wheels - $350 Type34 Land Rover Parts and Accessories 1 03-25-2008 01:58 PM
Vibration on DII with 19" Range Rover Wheels (hubcentric rings installed) W7412R Discovery Series II 4 09-12-2006 04:22 AM
OEM 19" Wheels for 2005 Range Rover HSE Desert Rover Land Rover Parts and Accessories 10 07-13-2005 02:48 PM
19" Range Rover wheels ibjettin Land Rover Parts and Vehicles Wanted 4 07-05-2005 10:44 PM
