Old 07-23-2008, 07:46 AM   #1 (permalink)
Question 1997 Range Rover 4.6 HSE .......
Hello,
i have a range rover 4.6 HSE, wo will no longer run.
There is no firering up on the sparkplugs, there are different messages comming on the dashbord "Doors open, Roof open, Engine locked,....." and manny more.
Al happend after a leakage from the cooler, the wiring under the hood was wet.
I don't know where to look, somebody an idea.
It starts but thats all, it wil not run.
Any idea is welcom.
snuif is offline   Reply With Quote
Old 07-23-2008, 05:22 PM   #2 (permalink)
Clean all of your grounds. I had a similar problem when I bought my 97 HSE. I even had to replace (cut 1" off) the cable going to the starter, because it was corroded. It looked good on the outside, but inside it was all corroded.
jrandsu is offline   Reply With Quote
Old 07-25-2008, 04:44 AM   #3 (permalink)
Ok, all "Error Messages are gone" and the next problem is arrived.[/font]
Display message "Engine Locked" - "Press Unlock Key" after i do so it says "Engine Start", when i turn the ignition key nothing happens no cranking, so also no firing.
All fuses checked and they are OKE.
So i'm at the end.
On the passenger drivers side (Eurpean Version) i found a totaly oxcidated connector (green oxcidated water) wich goes to the
Body Electrical Control Mod-ule (BECM), so that thing is to repair first.
BECM box is dry, no water or anything else, all cable connections OK.
I repaired the connector, i have shortcuted the startmotor and it was crancking and again no firing, petrol pressure is oke.
Somebody any idea, where to look next.
Land Rover unveils Range Rover Autobiography for British show Administrator Land Rover News 2 09-29-2008 06:25 AM
I need help buying a Range Rover bmilcetich General Land Rover Discussion 10 08-29-2008 07:38 PM
1997 Range Rover, HSE, Bright Yellow maninin General Land Rover Discussion 10 11-28-2006 02:37 PM
British To The Core - The Land Rover Defender Serg General Land Rover Discussion 1 01-12-2006 11:57 PM
Range Rover Sport Seems to have it all Serg General Land Rover Discussion 1 12-05-2005 01:54 AM
