Old 06-10-2008, 03:07 PM   #1 (permalink)
Default 1999 4.0 SE has bosch engine syst?
i am looking at a used 1999 4.0se black w black interior.
can somebody clarify that it is the bosch engine syst, or do i need to get the vin and or manufacture date from seller? thank you
http://www.rangerovers.net/modelspecs/1999.html"
1999 Model Year Statistics
Base Price $58,625 (Kelley Blue Book) Weight N/A lbs. Warrantee was 4-Year 50,000 miles.
**Early 1999 Range Rover 4.0 models were actually exactly the same as the 1998 models since there were slowdowns in starting the production of the new models with the Bosch fuel injection system. The 4.6 HSE model was sold out due to strong demand, and the only “left over” 1998/99 models were 4.0 SE models. Land Rover rebadged these left over models as “4.0” (without the SE) and “4.0 S” (without the E). If you looked closely on most of the models you could see where the S or S and E were peeled off.
new engine
Powertrain:
After the limited run of 1999 4.0 and 4.0S models that had the same 4.0L/Lucas FI engine as the 1998 models Land Rover introduced a new 4.0 SE and 4.6 HSE with Bosch fuel injection engine management (the same engine management as the BMW 7 Series). "
wjones1396 is offline   Reply With Quote
Old 06-12-2008, 02:30 PM   #2 (permalink)
hermanpj's Avatar
Gallery: 4
you can clarify by looking at the engine. GEMS engine management system is a metal intake plenum that is rectangular and would say 4.0 on it.
Bosch intake plennum is less distinct - more of a metal zigzag of tubular shapes, without the distinctive large single metal box shape on top.
GEMS Engine:
Bosch Engine:
Pat Herman
Bosch plats. Elemental The Lounge 9 02-13-2007 09:55 AM
Any body doing electric hybrid in a LandRover? Adam in NYC USA Hybrid 54 12-23-2006 11:39 PM
P38 ..Non-Starter!! Fozzy Range Rover P38, Mk III and Range Rover Sport 25 04-12-2006 04:50 AM
1999 4.6 needs some work; fix or sell? Spring Range Rover P38, Mk III and Range Rover Sport 17 01-29-2006 02:18 PM
Custom fabrication people.. I have a pair of turbos 02disco2 Discovery Series II 9 01-24-2006 08:53 AM
