Old 08-05-2006, 01:48 PM   #1 (permalink)
Default 2000 RR Navigation System
Hello:
I have a 2000 Range Rover and recently ran into problems with the navigation system.
When I tired to use the system recently it said that the CD was not loaded. I went to the back of my truck and noticed that the CD was ejected. I put the CD back in went back to the front of my truck to see if there was any response, and nothing. Same problem. No CD present. Went back to the back of the truck and noticed that the CD had ejected itself. I tried turning the truck off and then back on… No effect.
I also noticed that after I click okay to the message that states that there’s no disc present, the only available option is to put the system to standby. Other than that, I have also noticed a red lettered “TMC” message on the bottom line status bar – it is exactly centered on the status line.
Any hints / recommendations on how I can get the system to hold the CD without ejecting it. Has anyone experienced the same before? If there is in fact a problem with the system – I just hope that the extended warranty would cover.
Thanks!
JJ
dbs600 is offline   Reply With Quote
Old 08-05-2006, 02:06 PM   #2 (permalink)
LR certified will cover it.
Sounds like the issue is the button, And I doubt no fix except a new one will do.
Old 08-06-2006, 12:19 AM   #3 (permalink)
rover4life:
thanks for your reply.
when you say button do you mean the eject button?
i know that the 2001 - 2002s had a newer nav systems - hopefully that would be what they replace mine with!?
jj.
