Old 05-21-2008, 09:36 PM   #1 (permalink)
Default 2002 Range with climate control stuck on high and coolant on passenger floor!HELP!
Well I did some searching but did not find much. My 02 Range rovers climate control just got the good old book symbol the other day when my wife was driving it, today I did some investigating and noticed it looks like dye has been placed in the coolant and it is leaking on the passenger floor is saturated. I can adjust the fan speed but the blower on the drivers side just stays a steady pace. Everything works such as the temp and fan speed shows it can be turned up and down but it will not turn down on drivers side. Manual just says bring to dealer but I'm not looking to do this. Any info appreciated.
matz445 is offline   Reply With Quote
Old 05-22-2008, 03:09 PM   #2 (permalink)
dsfloyd's Avatar
the coolant on the floor is usually a heater core gone bad. Not sure if the blower malfunction is related to that or if the control module for the climate control is bad.
'60 Series II 88
'04 Silverado 2500 4x4
'02 Altima 2.5 (Hurts less at the pump)
dsfloyd is offline   Reply With Quote
Old 05-23-2008, 04:17 PM   #3 (permalink)
I put some stop leak in and think I took care of the leak for now. Today I pulled the cabin filters and they were completely clogged with junk. Also the foam in the cowl is pretty much gone. Anyone know if either of these can cause a fault in the system?
Old 05-26-2008, 03:42 PM   #4 (permalink)
hermanpj's Avatar
Gallery: 4
clogged cabin filter will not cause the problem you are reporting. you can get leaves and little twigs down into the air ducting, and these will make a lot of noise. potentially they could get sucked into the ac blower motor and stop it, but they could not cause it to only run on high speed.
to me it sounds like you either have a problem with the HVAC control unit or a problem with an electrical component in the system such as a relay.
Pat Herman
Old 05-29-2008, 01:10 PM   #5 (permalink)
Is There Any Way To Test The Relays? Thanks
Old 06-01-2008, 11:42 AM   #6 (permalink)
hermanpj's Avatar
Gallery: 4
I think there is test equipment for relays, or you maybe can use basic electrical equipment like voltmeter and potentially a wave form analyzer... im not electrically inclined though...
Pat Herman
[All] Pre 96 OBD1 Fault Codes TerryS Tech & DIY 0 01-26-2007 07:00 AM
obd two codes Rovin4life Discovery Series I 4 12-25-2006 09:16 AM
0BD 2 code list Rovin4life Range Rover P38, Mk III and Range Rover Sport 1 12-19-2006 06:43 PM
1999 4.6 needs some work; fix or sell? Spring Range Rover P38, Mk III and Range Rover Sport 17 01-29-2006 01:18 PM
Range Rover Sport Seems to have it all Serg General Land Rover Discussion 1 12-05-2005 12:54 AM
