» Sponsors
» Sponsors
Old 10-03-2009, 01:54 PM   #1 (permalink)
2003 MK III Range Rover
Default 2003 Range Rover Alternator not working
Hello all,
is there a fusible link anywhere on the charging system for a 2003 Mk III? I have no charging current coming from the alternator.....gulp.
scotyount is offline   Reply With Quote
Old 10-04-2009, 09:40 AM   #2 (permalink)
nobody knows?
Wish I still had my D90
Old 10-04-2009, 11:44 AM   #3 (permalink)
House Trained
Prodigy999's Avatar
no. there is a diode built into the engine harness but that's all. If you pull the alternator out, you'll probably see that the outside body of it is scorched. If your RR was ever driven without coolant, it could have overheated the alternator to death. If you didn't know, those alternators are water cooled.
03 Disco 2 SE
3" OME CDL and D1 shifter
Prodigy999 is offline   Reply With Quote
Old 10-04-2009, 12:01 PM   #4 (permalink)
unfortunately I do know. Never driven without coolant......I am worried that it is the bad part.....they cost a lot....
Old 10-04-2009, 01:04 PM   #5 (permalink)
House Trained
Prodigy999's Avatar
yes they do cost a lot. You may be able to find one used for a BMW but I have never looked. I've replaced a few of those things and I'm willing to bet that is your problem.
03 Disco 2 SE
2003 range rover transmission overheat code 7caratkid Range Rover P38, Mk III and Range Rover Sport 11 10-21-2009 10:28 AM
2003 Range Rover MK3 - software revert? flyingboy Range Rover P38, Mk III and Range Rover Sport 0 06-25-2009 01:49 PM
I need help buying a Range Rover bmilcetich General Land Rover Discussion 10 08-29-2008 07:38 PM
Land Rover: Truly 'Extraordinary' Serg General Land Rover Discussion 0 01-31-2006 12:37 AM
22 inch custom wheels for 2003 Range Rover sambo4670 Wheels and Tires 1 07-15-2005 03:45 PM
