Old 05-03-2005, 09:52 AM   #1 (permalink)
Question 2003 rr display problem
my display is stuck in a vertical hold. is there any way to fix this or does anyone know the actual part that solves this.
brickslanga is offline   Reply With Quote
Old 05-04-2005, 12:28 AM   #2 (permalink)
Landy-Andy's Avatar
Default Display stuck...
Not sure if it will help....but,
I've heard of a lot of electronic issues solved by dissconnecting the battery for an hour & then reconnecting. This "defaults" or "resets" some things to factory spec. Probaly wont help your display, but worth a shot.
Oh, make sure you know your radio security/reset code before dissconnecting (if you have one set up).
good luck,
Andy
Landy-Andy is offline   Reply With Quote
