2006 to 2010 Headlight Conversion Wiring Help PLEASE!!! - Land Rover Forums : Land Rover and Range Rover Forum
» Auto Insurance
» Featured Product
Old 06-04-2010, 10:23 PM   #1 (permalink)
Default 2006 to 2010 Headlight Conversion Wiring Help PLEASE!!!
Ok I was trying to finish up the 2010 conversion before I take the truck into the body shop for paint and installation of the Overfinch body kit and I am still having some problems with the wire diagrams. I was actually able to get a 2010 front headlight wiring diagram and a 2006 headlight wiring diagram. I think I am still doing something wrong, because after wiring up the headlights I still have a few issues. I tried to follow the instructions on l322.com but his car is a 2002 and not a 2006 which has adapted headlights.
THINGS THAT WORK
Xenon Low Beam
Halogen High Beam
Turn Signals
THINGS THAT DONT WORK
adaptive headlights
angel eye and side marker flicker when xenons are turned on
headlight error on dash indicator light.
I pretty much need anyone who has finished the conversion to let me know which pins I am connecting that are messed up. I am assuming once I get the wires correct, the angle eyes and side markers won't flicker, the adaptive headlights will work, and I will have no error lights on my dashboard.
PROBLEMS!!!
Right now I have an headlight error on my dashboard. I can't get the adaptive lights to flash up and down when the cars starts. The angel eyes and side marker flicker when the xenon are turned on. They work fine when in parking lamp mode only.
The 2010 headlight plug has missing pins on 5,6,7,8.
So there is only 12 pins to connect up.
I also had a questions about pin 8 on the 2006 headlight. It looks like pin 8 and pin 13 on the 2006 wire diagram are connected to the trucks canbus system. Problem is there is no pin on the 2010 modules for this. I am almost there. Just need a little help.
Here are the wiring pins for the 2006 and 2010 headlights.
2006 Range Rover HSE Supercharged
RWDRIFT is offline   Reply With Quote
Old 06-05-2010, 06:49 AM   #2 (permalink)
WE DO IT BETTER... FOR LESS!
westminster's Avatar
Exclamation
Hi, the 2010 modles incorporate an LED lighting system into the lamps. these LED's require different ciruitry to enable correct function, such as resistance and amp's. installing this system on a 2006 may result in undesirable vehcile function including performace. I would think that a further circuit modification would be required, howevere would not recommend it.
westminster is offline   Reply With Quote
Old 11-02-2010, 02:13 PM   #3 (permalink)
NIM
Toronto Canada .Independent Land Rover Shop
Hi Did you get the wiring sorted out if not give me a call at 905 554 4530 or email me at nim@nvcustomsauto.com .
NIM is offline   Reply With Quote
Old 02-10-2011, 05:00 AM   #4 (permalink)
NIM
Hi i am sorry for not getting back to a lot of people who need my help in wiring these lights , but we are in the middle of moving our complete shop to a new location that is a lot bigger and we are cleaning up painting etc ,plus the shop is always full 10 to 20 trucks a day with only 4 of us, so hopefully by The 1st of March 2011 we will be in the new shop and by the 10th i should be able to post the instruction for you all , again sorry but i am running around like crazy Thanks Nim
Old 11-17-2012, 04:05 AM   #5 (permalink)
hi i am about to upgrade my 2006 range rover vogue to 2012 spec. I have bought all the parts & now i have been told i can't just plug the headlamps although the connectors are the same i need to have my wiring done by auto elec. i have tried half a dozen garages with no luck if anybody has done the modification on their vehicle please could you let me know many thanks. nad
nadeem is offline   Reply With Quote
  Land Rover Forums : Land Rover and Range Rover Forum > Land Rover Model Forums > Range Rover P38, Mk III and Range Rover Sport
2006 sport headlight issues daxbullodg Range Rover P38, Mk III and Range Rover Sport 3 10-19-2012 10:36 PM
2006 to 2010 Overfinch Supercharged Conversion RWDRIFT Range Rover P38, Mk III and Range Rover Sport 16 06-03-2012 04:27 PM
03-04 Headlight Conversion DONE Street Wolf Discovery Series II 52 02-27-2012 05:54 PM
Headlight conversion??? 6cuda6 Discovery Series II 6 05-12-2007 01:14 PM
headlight conversion jordieb213 Discovery Series II 1 07-31-2006 02:15 AM
SEO by vBSEO 3.3.2
