2006 range rover Westminster cold misfire - Land Rover Forums : Land Rover and Range Rover Forum
post #1 of 4 (permalink) Old 05-09-2014, 09:19 AM Thread Starter
Quoted: 0 Post(s)
Good day all!!
I have a 2006 range rover S/C westminster edition. I am experiencing cold misfires on just about every cylinder, however once the engine warms up she runs smooth as silk. Anyone else experience this problem? Doesn't appear there is bad compression on any cylinder. Also the rover shop I have taken it to had one with a similar issue. They have tried replacing cool packs, wires, tune up, and injectors with no luck. They did day they saw a bit of low fuel pressure so they are replacing the fuel pump to see if that helps. Does anyone have any ideas??
Thanks
Jon
roverguy44 is offline
post #2 of 4 (permalink) Old 05-10-2014, 06:31 AM
Jagfixer's Avatar
Quoted: 12 Post(s)
Garage
Is it throwing codes? If not it would be a fuel related issue as a cold start problem. Have you done a fuel pressure test?
Larry K, ASE
2011 LR4 HSE LUX
previous owns: 87 Classic
96 Disco, 96 P38
Jagfixer is offline
post #3 of 4 (permalink) Old 05-10-2014, 06:56 AM Thread Starter
Quoted: 0 Post(s)
Having one done now.. The only codes I get are misfire codes on multiple cylinders
post #4 of 4 (permalink) Old 01-10-2017, 09:18 AM
Quoted: 0 Post(s)
06 Range Rover
I have an 06 RR HSE 4.4 I have same problem random misfires only when cold once warm and restarted runs great I have put in it new coil packs new plugs new fuel pump and filter any ideas?
06 range rover is offline
  Land Rover Forums : Land Rover and Range Rover Forum > Land Rover Model Forums > Range Rover P38, Mk III and Range Rover Sport
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
User Tag List
Linear Mode Linear Mode
2006 Supercharged Westminster jbrown8973 Land Rover Vehicles 0 07-05-2013 03:36 PM
2002 Westminster Range Rover Problems Montana Rover Range Rover P38, Mk III and Range Rover Sport 2 01-22-2011 06:35 PM
2002 Westminster Range Rover Problems Montana Rover General Land Rover Discussion 0 01-10-2011 01:06 PM
Which 02' Range Rover Westminster to buy ? EUROTEK//RANGEROVER Range Rover P38, Mk III and Range Rover Sport 0 10-26-2008 02:08 AM
2006 Range Rover Sport Receives Automotive Lease Guide's (ALG) 2006 Residual Value Aw Serg General Land Rover Discussion 1 01-23-2006 11:29 PM
You may post new threads
You may post replies
