» Sponsors
» Sponsors
Old 07-02-2009, 06:40 PM   #1 (permalink)
RabbiCP's Avatar
Default 95 SE Suspension
I had to bypass the suspension, replaced the compressor and that didnt do the trick. Would the next thing to do be pop a new Computer in?
Chas
RabbiCP is offline   Reply With Quote
Old 07-02-2009, 07:32 PM   #2 (permalink)
LoWBuDget RoVer's Avatar
Gallery: 10
Your guess is good as mine
Be Positive , Check my Youtube Profile: http://www.youtube.com/user/twowheelsnobrain
Rover almost 90% Fixed before I Sell it
Does anyone know of 12" subs under ($200 to $60)
LoWBuDget RoVer is offline   Reply With Quote
Old 07-06-2009, 06:46 PM   #3 (permalink)
Gallery: 2
Default Eas Response
Chas
Have you returned everthing to it's original state? Do you have the EASunlock software yet? Do you have any faults that need resetting? I have gone thru the same thing, email me if you have any questions.
Shaun
shaunmac2002 is offline   Reply With Quote
Old 07-17-2009, 07:34 PM   #4 (permalink)
Default Eas
Hi,
Sounds like you have a bad sensor, if not , more than one.
You should not have to replace anything but the sensors. If the pump stops running, ground the vehicle harness-side EAS pump ground wire (small, prob. green) to the chassis.
The vehicle will fault on the dash if one sensor is bad; but if 2 are bad on the same axle, the car will drop to the bumpstops, and give a fault.
Look to get some new o-rings for your suspension from rover-renovations.com.
-GD
GreenDogRovers is offline   Reply With Quote
Suspension Issues rmuller Discovery 3 / LR3 1 01-20-2009 12:02 PM
DII Suspension (and related questions) 101 SCSL Discovery Series II 25 07-29-2008 12:16 AM
Rims & Air Suspension Parts 4Sale...PICTURES Jigsaw89 Land Rover Parts and Accessories 8 11-23-2007 09:47 AM
Oh man...(flame suit is on) 02disco2 The Lounge 9 03-27-2006 12:51 PM
