» Sponsors
» Sponsors
Old 09-22-2009, 07:39 AM   #16 (permalink)
justin.boyle's post has alot of similarities to John Miller's post a few up from his...
RangeRover96 is offline   Reply With Quote
Old 10-10-2009, 01:58 PM   #17 (permalink)
Chrome Plated Cardboard
Gallery: 5
Dude I knew that was a phoney post!
What a loser patting himself on the back like that!
That's FREAKING HILARIOUS!!
"Oh I'm such a good seller blah blah vast sums of trust bucket pleasure!" hahahhaha
I am seriously cracking up right now. :-)
Later,
Tom
Tom Sederburg is offline   Reply With Quote
Old 10-19-2009, 11:58 AM   #18 (permalink)
If you ask me he's a crook and a scam artist IMO...
Old 10-25-2009, 02:51 AM   #19 (permalink)
In the midst of all that, this was actually an excellent post.
Originally Posted by GreenDogRovers View Post
If you just bought a P38, and don't know much about them, PLEASE CHANGE YOUR AIR POLLEN FILTERS...It is likely nobody has changed them in some thime. These allow air into the cabin, via the fresh air intake below the windsheild. Failure to change these air filters will lead to overheating of the fans (2) electrical circut, and will cause the circutboard in the fusebox to burn, which can cause all sorts of problems.
If your dash lights come on when you depress the pedal, it is time for a new ABS accumulator ball. These go bad after about 7 years, as the nitrogen in the diaphragm inside of it changes chemical composition, and renders the ball useless, offering no assist to the brake booster, which in turn makes the pump run too often, which can burn out the pressure switch on the Abs pump, making it VERY hard to stop the vehicle (if at all).
Another thing...if your EAS pump stops working (providing you still do have the air suspension, and someone else didn't already quit trying, and just put springs on it...) you can unplug the ground wire from the vehicle harness-side of the multiplug that goes to it, and ground it to the body, bypassing the (stupid) thermal switch. When the pump gets too hot, it trips the thermal switch, usually rendering the pump useless, and in need of replacement (another mechanic special). This will save you between $300-2800 (seriously).
Anyway, these are just 3 of the things that go wrong with P38's that mechanics like to charge an arm and a leg for.
Yes, and as someone else said...Get the Rave CD...If you can't get one for free, get one on ebay for about $8.00. The CD has full manuals for your vehicle, and is the most helpful reference to have when owning a rangie
I'm sorry you had a bad time with your P38. They are excellent cars, amazing ride, bags of refinement. Not knocking the Toyota, just a matter of taste.
'97 4.0SE, Manual, UK Spec.
Rasheed is offline   Reply With Quote
New '98 Range Rover HSE owner excited but billadamsrealty New Member Introductions 3 03-23-2009 03:27 PM
Land Rover parts 20.000 items Range Rover Ltd Range Rover Classic 20 01-30-2009 02:37 PM
classic 91 range rover owner gregalderette New Member Introductions 9 03-13-2008 12:30 AM
Made-Over Rover (LR3) Serg General Land Rover Discussion 0 12-02-2005 12:07 AM
RamAir Air Filter for Land Rover Discovery 1 95 Range Rover Classic $25.00 hamrendan Land Rover Parts and Accessories 0 01-24-2005 09:08 AM
