Hmmm. You removed the drivers handle cap and the key won't turn? Why wouldn't the key match? Tow it in to the dealer if you have warranty... If your warranty is out, remove the lower engine tray (ten 13mm bolts) and hook up a jumper box positive to either the starter power wire or the alternator power wire and the engine block for ground. Once you have power, unlock it with the key remote. Then get your door lock fixed as soon as possible.
03 Disco 2 SE
3" OME CDL and D1 shifter
