Links
Old 04-30-2008, 06:28 AM   #1 (permalink)
1998 Range Rover
Default blocked pcv?
I got a suggestion that a blocked pvc breather system could be causing my oil leak...however for a p38 I can hardly find any info on it...any tips for cleaing it out? thanks
roverbryan08 is offline   Reply With Quote
Old 05-15-2008, 06:28 PM   #2 (permalink)
pgf
Yes,
I had the same in my 4.0l. In my case someone has replaced the PCV hose with heater hose that collapsed when hot causing blockage. From what I understand there is a small mesh filter in the engine end of the breather hoses. I'd pull apart and cleana nd reassemble??
pgf is offline   Reply With Quote
