a clunk going over small bumps - Land Rover Forums : Land Rover and Range Rover Forum
» Auto Insurance
» Featured Product
Old 11-19-2012, 07:11 AM   #1 (permalink)
Default a clunk going over small bumps
Hi guys my 07 plate rrs has developed a clunk ( knock ) on the nearside wheel area when going over a small bump, also at 50ish mph theres a slight wheel wobble ( has been balanced ) not sure if this is related.
mickyled is offline   Reply With Quote
Old 11-19-2012, 04:12 PM   #2 (permalink)
Super Trooper
cnfowler's Avatar
Gallery: 3
The clunk is probably the a arm bushings.
Colin
cnfowler is offline   Reply With Quote
Old 01-07-2013, 08:31 AM   #3 (permalink)
Wear in the lower ball joint or anti roll bar bushes.
russfenwick is offline   Reply With Quote
Old 01-30-2013, 10:01 AM   #4 (permalink)
Default a arm bushing
Colin
Do you have any idea how much this would cost to repair?
lbryantsr is offline   Reply With Quote
Old 01-30-2013, 10:18 AM   #5 (permalink)
NIM
Toronto Canada .Independent Land Rover Shop
I would suggest you replace the arms and get 4 bolts and washer as these seize onto the inner of bushings arms are usually about $380.00 for each arms, bolts and washers about $32.00. lab with Alignment between $350.000 to $550.00
NIM is offline   Reply With Quote
  Land Rover Forums : Land Rover and Range Rover Forum > Land Rover Model Forums > Range Rover P38, Mk III and Range Rover Sport
Loud thud going over bumps texasdiver72 Range Rover Classic 8 12-12-2009 03:18 AM
Bad vibration when hitting bumps LR4U Discovery Series I 3 05-12-2009 02:32 PM
clicking going over bumps AzCamel Discovery Series II 7 09-12-2005 09:21 PM
Freelander - bumps and grind in the nite garrycol Freelander / LR2 3 04-29-2005 07:07 PM
SEO by vBSEO 3.3.2
