Old 02-12-2007, 08:57 AM   #1 (permalink)
Default Coil Spring Conversion... HELP!!!
Hey guys, I purchased the BlackDog coil spring conversion online and cant find the directions to overide the module. Does anyone have the directions from their BlackDog kit to fax me. Please Help.
925.750.9096 fax
randy_purnell is offline   Reply With Quote
Old 02-12-2007, 02:56 PM   #2 (permalink)
Hi,
Locate the EAS control module beneath the drivers seat. (This will be the lowest module, beneath the transmission control module.)
Disconnect the module connector.
In the wiring harness leading to the module, locate the BLUE wire with the PINK stripe.
Cut this wire and permanently ground.
Locate the BLUE wire with the WHITE stripe and temporararily ground.
Turn the ignition to the "RUN" position.
Listen for the audible alert, then remove the BLUE/WHITE wire from the temporary ground and tape up the end to avoid shorts.
This will put the module in EAS Manual mode.
Leave module connector unplugged.
Phew !!!!
Disco1 is offline   Reply With Quote
Old 02-13-2007, 08:59 AM   #3 (permalink)
Thanks for the info Disco1.
