Old 06-01-2005, 07:22 PM   #1 (permalink)
Default Dead battery!!!
I have a 2000 4.6, and within the past 6 months, the battery will die if I leave it sitting for over one or two days. I have a brand new Optima gel cell battery, and a new alternator. I don't see any lights that come on or anything, and there are no aftermarket parts that could drain the battery. Is it the BECM thing, or is there anything else to check? Does anyone know where to get another working BECM for a reasonable price? Please help!!!
2000 Range Rover 4.6
2001 Jaguar VDP
2003 Mercedes C32
2003 Jeep Wrangler
______________________
Rover + Jaguar = Glutton for Punishment
petespokerplanet is offline   Reply With Quote
Old 06-01-2005, 11:14 PM   #2 (permalink)
Super Moderator
Disco's Avatar
It is possible that the battery is not holding it's charge and I have never had any nice things to say about gel cell batteries anyway. I have 5 Odysseys of various ratings (all dead) in my garage. I now run normal wet cell batteries.
I would check the battery first. If this checks out, then you do have a power drain or interference somewhere that's keeping the BeMC awake and causing your drain.
Old 06-02-2005, 04:28 AM   #3 (permalink)
VOGUE SE's Avatar
I'm going for the BECM. Did you already try to park your car at another place?
Happy owner of a RANGE ROVER DSE HOLLAND & HOLLAND, RANGE ROVER VOGUE SE and DISCOVERY 300TDI.
VOGUE SE is offline   Reply With Quote
Old 06-02-2005, 04:33 AM   #4 (permalink)
TerryS's Avatar
I'm with Disco. I have found Optimas to have huge swings in quality and longevity, and just not worth the extra money. I'll stick to a quality 60 month Lead-Acid, for 1/3 the price.
Old 06-02-2005, 04:37 AM   #5 (permalink)
Bogatyr's Avatar
petespoker...
You're going to need a multimeter to see what voltages are going round...
What does the battery have at rest? What's the voltage at the terminals with the vehicle running? Next, put the meter inline between the positive terminal and the positive cable to see what kind of drain there is (hopefully on the miliamp scale). You'll then need to reference that number with the shop manual to see if it's in an acceptable range...
Bogatyr
Current Rover Fleet:
Old 06-02-2005, 07:01 AM   #6 (permalink)
Well, this is the second battery, and according to the auto parts store, it checks out well within specs. I am assuming it is something else. Are there anyother signs to look for?
2001 Jaguar VDP
2003 Mercedes C32
2003 Jeep Wrangler
Old 06-02-2005, 10:59 AM   #7 (permalink)
Bogatyr's Avatar
petespoker...
Well, I'd check to see what the alternator is putting out. If that's ok, and there is an excessive draw on the battery when the vehicle is not running I'd suspect something like the becm...but I'm a series guy...I can't tell you any specifics on testing something newfangled like a vehicle with an alternator...the shop manual would have, I'd assume, some testing procedures for the becm...
Bogatyr
Old 06-02-2005, 06:06 PM   #8 (permalink)
I have heard cell towers can keep the BECAM awake, I have a friend who park at the airport and the battery has gone down on him a couple times. Try not locking the truck and see what happens.
lonestarrover is offline   Reply With Quote
Old 06-03-2005, 12:14 AM   #9 (permalink)
It is possible that the BeCM is not going to sleep. To check, look at the red dot that shows the gear position. The light should glow dim when the ignition is switched off and eventually turn off. You have to check it with out opening any doors. As soon as a door is opened or the remote is activated the BeCM will wake up.
RoverMD is offline   Reply With Quote
Old 06-05-2005, 10:54 AM   #10 (permalink)
Landy-Andy's Avatar
Default Old trick...
Hi,
One old trick to find whats still drawing current is to close all doors, turn everything off, take the key out of the ignition.
Then, slowly pull one fuse out of the fuse box at a time, slowly put each fuse back in, if there is current draw you will see a small amount of sparking as you push the fuse back in that indicates some current draw across the fuse.
This is not a 100% accurate way of fault finding, but it will tell you what's drawing from the battery after everything is turned off.
Good luck,
Andy
Landy-Andy is offline   Reply With Quote
