» Sponsors
» Sponsors
Old 10-30-2009, 09:16 PM   #1 (permalink)
Chrome Plated Cardboard
Gallery: 5
Default Defroster Not Working Either?
The defroster on my '96 4.0 SE is also broken and does nothing - blows no air whatsoever - when I turn it on.
I ordered a new climate control unit, but if that doesn't correct this issue is there anything else I should try?
Later,
Tom
Tom Sederburg is offline   Reply With Quote
Old 10-31-2009, 07:09 AM   #2 (permalink)
Later,
Tom
Blend door motors? Fan units? fuses/relays
If the fans are not running. check the fuses under the hood, if they are good,look for the relays (yellow) and swap them with other relays (same types) in the box. I have seen the fuse box melt under the relays.
You should take it to a shop that can read the codes and see whats not working. A little daig may save time and money in the long run.
Kevin
95 RRC wifes
92 RRC mine
72 Series 3
Morgan + 8 (with a 4.6 racing engine with 4 Webers)
90 jetta with 300K
kevin-ct is offline   Reply With Quote
Old 10-31-2009, 11:29 AM   #3 (permalink)
Gallery: 5
Thanks Kevin. You give good advice. I will look at the fuses.
Later,
Tom
Mi Uno Y Solo Land Rover - 1996 RR 4.0 SE
WTB - Any 00-02 Style Console Cupholder Under $100 In Any Color/Condition. Please Contact Me If You Can Supply This Item.
Windshield washer quit working in full stream sowr Discovery 3 / LR3 1 04-18-2009 09:58 AM
I used to have a working front windshield defroster.... ArmyRover Range Rover Classic 23 04-16-2008 08:47 PM
Revometer not working KyleMan Discovery Series I 3 01-11-2006 06:31 AM
partial working Clock oceanswithin Discovery Series I 3 06-09-2005 09:09 PM
P38a-rear passenger door lock not working troverman Range Rover P38, Mk III and Range Rover Sport 1 04-07-2005 02:02 PM
