» Sponsors
» Sponsors
Old 09-11-2009, 10:55 AM   #1 (permalink)
Default Disable Chime
I have an 08 Sport, is there away of either disabling the seatbelt chime or reducing the volume level as it drives me nuts!
Bobby_1959 is offline   Reply With Quote
Old 09-11-2009, 01:29 PM   #2 (permalink)
I'm in my avatar too
mudmonkey's Avatar
I had this exact same problem...Doesn't just chime when you start driving but keeps going constantly as you drive.
I found a little clip about 2" by 4" with a hole in it around 1" square. When inserted into the seat belt socket, it fools the vehicle into not chiming. Mine came with the vehicle- it's located just behind the drivers shoulder on the door post and luckily it is connected by a handy strap to stop you from loosing it. Best thing to do is sit down- pull the little clip across you and stick it in the receiver. The straps are on a roller so they won't bother you too much as they cross your shoulder and lap.
As a Fireman who goes to accidents, my advice would be -Where your fu%king seatbelt - it means we don't have to walk as far to pick bits of you up
D2 with stuff added and some removed
mudmonkey is offline   Reply With Quote
Old 09-12-2009, 02:06 AM   #3 (permalink)
Go to ebay. HOW TO STOP the seat belt chimes on a Range Rover Sport/Disco/Freelander. £4, it takes 2 mins and can be done very easily. TROJAN
TROJAN is offline   Reply With Quote
Old 09-12-2009, 08:46 AM   #4 (permalink)
put your seatbelt on? just a thought...
if you jumper the wire, the airbag will react differently and can blow in your face in a crash.
it has also has seat sensor that determines if the person in the seat is a certain weight and will judge how to blow the bag.
1999 Disco2
KyleT is offline   Reply With Quote
97 Discovery SD how to get door chime to work LRDisco97US Discovery Series I 2 07-12-2009 05:42 PM
Front Parking Sensor Disable - 2007 LR3 2007LR3 Discovery 3 / LR3 2 06-09-2009 07:57 PM
SLS warning chime - spring converted 98xc800 Discovery Series II 1 03-12-2009 06:45 PM
96 range rover alarm disable how to do it hanivw Range Rover P38, Mk III and Range Rover Sport 2 02-26-2008 08:08 PM
no chime at climate cntrl REFERJOHN Discovery Series II 0 01-28-2006 11:19 AM
