Links
Old 04-04-2006, 10:24 PM   #1 (permalink)
Exclamation Fuel Filler Lid or Gas cap cover Won't Open
Hi Everyone,
I just bought a 1998 4.6HSE and the previous owner had a problem with the fuel cap cover not opening. When you press the switch, there is an audible click but nothing happens. Any help would be appreciated.
Gush
gush is offline   Reply With Quote
Old 04-04-2006, 10:36 PM   #2 (permalink)
ภาษาไทย
llesra's Avatar
Gallery: 16
dont know how to fix the switch but there should be a door on the passenger side with a string in the trunk. open the door and pull the string and the gas door will open
Arsell
My Car Domain Site
llesra is offline   Reply With Quote
Old 04-05-2006, 12:10 AM   #3 (permalink)
I did open the door. I am just curious if this is a common problem and how can I fix it?
Old 04-05-2006, 12:36 AM   #4 (permalink)
ภาษาไทย
llesra's Avatar
Gallery: 16
read this
http://www.rangerovers.net/repairdet...lerswitch.html
Arsell
My Car Domain Site
Old 04-05-2006, 12:51 AM   #5 (permalink)
Lovely.. Thanks for the help!
Old 04-07-2006, 12:08 PM   #6 (permalink)
Default not a problem....
Gas Filler Lid Switch
The switch on the dash that opens the gas cap lid has often been known to fail -- even causing vehicles to be towed into the dealer through inability to gas up. If this happens to you, remove the right hand side panel in the load space so you can reach in and operate the latch from the inside by hand. If you are concerned about this problem occuring, you can take preventive measures by a) getting an updated switch installed and b) attaching a string or wire to the inside of the latch in advance, leading it out through the access door at the rear of the load space side panel. Rafael Herbosa had his first romance with his Range Rover when the gas filler lid would not open. He reports that he he modified the approach recommended here -- instead of adding a string, he bypassed the electrical circuit and created a nice small push button switch that activitates the actuator and wiring tapped on the rear light. His approach and others are detailed on the Fuel Filler Switch Fixes Page
Saludos
Pascal
Pascal
Pascaltissot is offline   Reply With Quote
