Old 02-22-2008, 03:27 PM   #1 (permalink)
YellowFever's Avatar
Default Fuel Gauge
I just bought a 2000 Range HSE. I noticed when I fill the tank up the gauge never makes it to the last notch. It only goes up to one notch prior. Then when I drive for about 1 mile it drops to about a half notch. I drove it until it was in the red and then some. I was able to get about 20.something gallons in it. Is this a gauge issue?
Thanks
Remember: Success is nothing but luck. Just ask any failure. - anon
Show me a good loser, and I'll show you a loser. Vince Lombardi
YellowFever is offline   Reply With Quote
Old 02-23-2008, 07:31 AM   #2 (permalink)
most likely but the tank has to be pulled from below.
the part on the pump is separate and should be replaceble. its a little arm with a wire on it.
Fuel Gauge Sender Installation Den Defender 4 06-28-2008 12:37 AM
Faulty fuel gauge. Militant-Grunt Discovery Series I 0 03-19-2006 08:02 PM
HELP!! Fuel Pump??? Truck still on trail. bluemax09 Discovery Series I 14 02-22-2006 03:40 PM
1999 4.6 needs some work; fix or sell? Spring Range Rover P38, Mk III and Range Rover Sport 17 01-29-2006 01:18 PM
fuel gauge quit working GentrysRover Discovery Series I 2 09-09-2005 05:04 AM
