Gearbox fault, I've tried EVERYTHING! HELP!!! - Land Rover Forums : Land Rover and Range Rover Forum
post #1 of 10 (permalink) Old 09-15-2011, 08:22 PM Thread Starter
Quoted: 0 Post(s)
Ok 95 Range Rover 4.0 P38... I turn the key, without starting, and immediately have a gearbox fault message. I have tried a new battery and different alternator, when I turn it over it drops to 11.3-11.5 and quickly ramps to 13.7-14.1 once it has started. Put it in drive and it shifts at 2200 RPMs in every gear, yes I have access to all gears, I can put it in 1st and hold the gear but it doesn't have as much power still. The check engine light is on thinking it is the o2 sensors... I have checked the MAF and TPS sensors by replacing them and the seem to be working. When I'm coming to a stop it down shifts HARD into 2nd and 1st. Any grounds that you know of that I should check would be awesome or if you think it's the ECU... I'm trying to avoid taking it somewhere just so they can give me and bill and still have a car with a problem.... Thanks for all the help!!!
NewbieRover is offline
post #2 of 10 (permalink) Old 09-15-2011, 09:29 PM
Rover-Holic and Admin
ArmyRover's Avatar
Quoted: 35 Post(s)
Have you actually pulled the codes to see what the truck is telling you?
1972 MGB
Coming Soon 2006 LR3
Trident Green, 1983 110
Need new parts, genuine Land Rover, aftermarket and off road upgrades, Support the Vendor that supports the Land Rover Community and Forum
716-898-8153
Have a DII you need a drive shaft click here
Want a
best read this first
Need used parts?
ArmyRover is offline
post #3 of 10 (permalink) Old 09-15-2011, 10:00 PM Thread Starter
Quoted: 0 Post(s)
I didn't think my car had OBDII and thus I have no idea how to retrieve the codes. I take it that a dealer has to do it?
post #4 of 10 (permalink) Old 09-16-2011, 04:08 PM
Quoted: 0 Post(s)
Post your location, as we are not mind readers and have no idea where you are located at..
The OBD plug is in the passenger footwell (NAS spec LHD).
Go to a parts store and have them read the codes for you.
Post the results.
Martin
leftlanetrucking is offline
post #5 of 10 (permalink) Old 09-25-2011, 07:30 PM
Quoted: 0 Post(s)
pull your codes.
mine was starting to do the same thing. it ended up being the crankposition sensor. the part was $75 and only took about a hour to swap out. my hands are to fat to get into it easily. once i swapped it out, all my problems went away.
getlost4x4 is offline
post #6 of 10 (permalink) Old 09-26-2011, 05:20 AM
Quoted: 11 Post(s)
While one should certainly investigate the easy and cheap OBD-II scanner responses, if this turns out to be a transmission/controller problem, you'll need to take it to someone with a Rover-specific diag computer.
The most common cause for the fault you have is electrical-related. It will be interesting to find out what the issue is here.
Yes, I am still alive, and still in the Rover parts business.
Text me for greatest likelihood of finding me.
260-804-0458
Dominic Perodeau/Global British is a thieving bastard, do not send him money.
PTSchram is offline
post #7 of 10 (permalink) Old 10-21-2011, 06:03 PM
98NiagaraRR's Avatar
Quoted: 0 Post(s)
Why dont you just check and drain the transmission fluid? Draining the transmission is as easy as changing the oil on our trucks.. May not take away the codes but probably will help with the rough shifts. The bolt is on the bottom of the transmission. Once you got it all out, make sure you use a strong thread locker to keep the fluid from leaking out when you drive.
98' RR 4.6HSE
00'-02' painted OEM front bumper and dual exhaust, tinted signals all around, black suede interior accents, factory subwoofer swapped to a 15" JL Audio
Bilstein Shocks and Eibach Spring conversion, RR Sport 20" Stormer Wheels
96' RR 4.0SE
Tinted signals all around, black suede interior accents, coil spring conversion
98' Volvo C70 HPT
PIAA headlights, clear corners & eyelids
98NiagaraRR is offline
post #8 of 10 (permalink) Old 10-21-2011, 06:35 PM
ArmyRover's Avatar
Quoted: 35 Post(s)
probably since he hasn't been back since the last time he posted.
1972 MGB
716-898-8153
Want a
Need used parts?
post #9 of 10 (permalink) Old 11-08-2011, 04:53 AM
dayjavuu78's Avatar
Quoted: 0 Post(s)
I was having the same issues, and my tach was dropping to 0 which led me to thinking it was a voltage-related issue. I replaced the alternator, battery, and both battery cables, mainly because they were all in need of replacement. That fixed the tach and other minor problems, but not the gearbox fault message.
It turns out that the transmission wiring harness clip, close to the bell housing, had broke. As a result, one of the fine gauge wires in the transmission harness was making contact with the spinning driveshaft which resulted in the wire becoming severed. I soldered the wire back together and relocated the harness - the fault went rite away.
Also check the transmission and transfer case ECU's. Hope this helps.
-Mark
dayjavuu78 is offline
post #10 of 10 (permalink) Old 11-20-2011, 09:17 PM
Quoted: 0 Post(s)
Thumbs up
When i meet such prolbem,i will find my car engineer or other person for help.
i know one engineer at www.obdiichina.com is very professional in solving car problem,he help me much,maybe you can find him!
This is only my suggusetion!
Cicily2011 is offline
  Land Rover Forums : Land Rover and Range Rover Forum > Land Rover Model Forums > Range Rover P38, Mk III and Range Rover Sport
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
User Tag List
Linear Mode Linear Mode
P38 With LPG Gearbox fault HELP PLEASE. L4LEYDAVE Range Rover P38, Mk III and Range Rover Sport 2 05-26-2010 02:16 PM
P1775 Gearbox Fault vjm530 Range Rover P38, Mk III and Range Rover Sport 1 08-11-2008 11:36 AM
Gearbox fault warning message SPS Range Rover P38, Mk III and Range Rover Sport 1 01-09-2006 12:25 AM
Gearbox Fault--Again! troverman Range Rover Classic 4 03-22-2005 12:57 PM
electrical fault with automatic gearbox.. Help.. landrovdisco Discovery Series II 5 01-11-2005 10:15 AM
You may post new threads
You may post replies
