Gearbox fault, I've tried EVERYTHING! HELP!!! - Land Rover Forums : Land Rover and Range Rover Forum
» Auto Insurance
» Featured Product
Wheel & Tire Center
Old 09-15-2011, 09:22 PM   #1 (permalink)
Default Gearbox fault, I've tried EVERYTHING! HELP!!!
Ok 95 Range Rover 4.0 P38... I turn the key, without starting, and immediately have a gearbox fault message. I have tried a new battery and different alternator, when I turn it over it drops to 11.3-11.5 and quickly ramps to 13.7-14.1 once it has started. Put it in drive and it shifts at 2200 RPMs in every gear, yes I have access to all gears, I can put it in 1st and hold the gear but it doesn't have as much power still. The check engine light is on thinking it is the o2 sensors... I have checked the MAF and TPS sensors by replacing them and the seem to be working. When I'm coming to a stop it down shifts HARD into 2nd and 1st. Any grounds that you know of that I should check would be awesome or if you think it's the ECU... I'm trying to avoid taking it somewhere just so they can give me and bill and still have a car with a problem.... Thanks for all the help!!!
NewbieRover is offline   Reply With Quote Quick reply to this message
Old 09-15-2011, 10:29 PM   #2 (permalink)
Chicago where body armor is needed for a day in the park
ArmyRover's Avatar
Have you actually pulled the codes to see what the truck is telling you?
"If you can't stand behind our soldiers, then by all means stand in front of them." unknown author.
Need Parts?
www.lucky8llc.biz (716) 898-8153
PT Schram pt@ptschram.com
paulgrant@gmail.com
http://lucky8llc.com/L8Forum/index.php
1983 Land Rover 110 5 door wagon
1972 MGB
ArmyRover is offline   Reply With Quote Quick reply to this message
Old 09-15-2011, 11:00 PM   #3 (permalink)
I didn't think my car had OBDII and thus I have no idea how to retrieve the codes. I take it that a dealer has to do it?
Old 09-16-2011, 05:08 PM   #4 (permalink)
Post your location, as we are not mind readers and have no idea where you are located at..
The OBD plug is in the passenger footwell (NAS spec LHD).
Go to a parts store and have them read the codes for you.
Post the results.
Martin
leftlanetrucking is offline   Reply With Quote Quick reply to this message
Old 09-25-2011, 08:30 PM   #5 (permalink)
pull your codes.
mine was starting to do the same thing. it ended up being the crankposition sensor. the part was $75 and only took about a hour to swap out. my hands are to fat to get into it easily. once i swapped it out, all my problems went away.
getlost4x4 is offline   Reply With Quote Quick reply to this message
Old 09-26-2011, 06:20 AM   #6 (permalink)
While one should certainly investigate the easy and cheap OBD-II scanner responses, if this turns out to be a transmission/controller problem, you'll need to take it to someone with a Rover-specific diag computer.
The most common cause for the fault you have is electrical-related. It will be interesting to find out what the issue is here.
Yes, I am still alive, and still in the Rover parts business.
Text me for greatest likelihood of finding me.
260-804-0458
Dominic Perodeau/Global British is a thieving bastard, do not send him money.
PTSchram is offline   Reply With Quote Quick reply to this message
Old 10-21-2011, 07:03 PM   #7 (permalink)
98NiagaraRR's Avatar
Why dont you just check and drain the transmission fluid? Draining the transmission is as easy as changing the oil on our trucks.. May not take away the codes but probably will help with the rough shifts. The bolt is on the bottom of the transmission. Once you got it all out, make sure you use a strong thread locker to keep the fluid from leaking out when you drive.
98' RR 4.6HSE
00'-02' painted OEM front bumper and dual exhaust, tinted signals all around, black suede interior accents, factory subwoofer swapped to a 15" JL Audio Bilstein Shocks and Eibach Spring conversion, RR Sport 20" Stormer Wheels
96' RR 4.0SE
Tinted signals all around, black suede interior accents, coil spring conversion
98' Volvo C70 HPT
PIAA headlights, clear corners & eyelids
98NiagaraRR is offline   Reply With Quote Quick reply to this message
Old 10-21-2011, 07:35 PM   #8 (permalink)
ArmyRover's Avatar
probably since he hasn't been back since the last time he posted.
Need Parts?
paulgrant@gmail.com
1972 MGB
Old 11-08-2011, 05:53 AM   #9 (permalink)
dayjavuu78's Avatar
I was having the same issues, and my tach was dropping to 0 which led me to thinking it was a voltage-related issue. I replaced the alternator, battery, and both battery cables, mainly because they were all in need of replacement. That fixed the tach and other minor problems, but not the gearbox fault message.
It turns out that the transmission wiring harness clip, close to the bell housing, had broke. As a result, one of the fine gauge wires in the transmission harness was making contact with the spinning driveshaft which resulted in the wire becoming severed. I soldered the wire back together and relocated the harness - the fault went rite away.
Also check the transmission and transfer case ECU's. Hope this helps.
-Mark
dayjavuu78 is offline   Reply With Quote Quick reply to this message
Old 11-20-2011, 10:17 PM   #10 (permalink)
Thumbs up
When i meet such prolbem,i will find my car engineer or other person for help.
i know one engineer at www.obdiichina.com is very professional in solving car problem,he help me much,maybe you can find him!
This is only my suggusetion!
Cicily2011 is offline   Reply With Quote Quick reply to this message
  Land Rover Forums : Land Rover and Range Rover Forum > Land Rover Model Forums > Range Rover P38, Mk III and Range Rover Sport
Quick Reply
Message:
Options
Register Now
If you do not want to register, fill this field only and the name will be used as user name for your post.
Password
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
P38 With LPG Gearbox fault HELP PLEASE. L4LEYDAVE Range Rover P38, Mk III and Range Rover Sport 2 05-26-2010 03:16 PM
P1775 Gearbox Fault vjm530 Range Rover P38, Mk III and Range Rover Sport 1 08-11-2008 12:36 PM
Gearbox fault warning message SPS Range Rover P38, Mk III and Range Rover Sport 1 01-09-2006 01:25 AM
Gearbox Fault--Again! troverman Range Rover Classic 4 03-22-2005 01:57 PM
electrical fault with automatic gearbox.. Help.. landrovdisco Discovery Series II 5 01-11-2005 11:15 AM
Powered by vBulletin® Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.3.2
All content is copyright 2004-2008 www.landroversonly.com and its original authors. Land Rovers Only is in no way affiliated with Land Rover
