» Sponsors
» Sponsors
Old 11-05-2009, 04:27 AM   #1 (permalink)
Default Hard situation Head Threads strips
I m facing a hard situation, i m working on a P38 and one engine head bolt that i unscrew last night was very loose. I m pretty sure that the threads are busted. Does anyone had face this situation ? If so, i think to re-thread the holes with a bigger tap....my questions are; witch size tap i should buy and witch bolt from witch engine i should used ?
canadianDisco2owner is offline   Reply With Quote
Old 11-05-2009, 06:32 AM   #2 (permalink)
That's a common one. If you are pulling the heads anyway, you can do it on a press. If you aren't pulling them, it is a job for a 90 degree drill. Install a Helicoil and go on. I have seen folks use the thread former compound on one when they were selling one, but that isn't the solution. That is just a way to screw the next owner. Do the Helicoil and you will never have another problem with it. Be careful not to allow any shavings into the engine.
I think there might be some threads on Dweb about this.
1987 Range Rover
1989 Range Rover
1995 Range Rover County LWB
1998 Range Rover 4.6HSE
TNRRClassic is offline   Reply With Quote
Looks like it's head gasket time..... Woodland Rover Discovery Series II 22 07-29-2009 05:48 PM
How to Install Basic Aftermarket Head Unit in P38 95-97 marcust Range Rover P38, Mk III and Range Rover Sport 6 06-14-2009 12:21 AM
97 Disco 1 Head Gaskets LRDMICHELE Discovery Series I 15 03-18-2009 12:17 PM
head gasket/possible cracked head jdsmith46 Discovery Series I 7 01-02-2006 01:22 PM
