Heater, coolant leak question for 2000 P38 - Land Rover Forums : Land Rover and Range Rover Forum
» Auto Insurance
» Featured Product
Old 02-09-2007, 03:25 PM   #1 (permalink)
Default Heater, coolant leak question for 2000 P38
Hope someone can help me with this. I am assuming it is a heater core problem but doing some odd things....
1) When car is under load (starting from stop mostly) it sounds as if there is a little man in my glove box who is shaking a half empty plastic milk jug. If I add water to res. it quiets down or stops for awhile.
2) Often times, there is a few ounces of coolant on my garage floor in the morning. I thought it was just from overflow at res. but it seems to also be dripping off the passenger side rocker.
3) Coolant on passenger side floor (classic sign). Not a ton, but enough to get bottom of rubber matt wet, etc.
Car has 107K miles. Do you think this is heater core or possibly other problem or problems? I am waiting for my Rover factory service manual to arrive (just ordered) and was going to attempt to repair myself but don't know how deep I gotta dig to do it. Or how many labor hours it will cost at a shop. I also have a flap stuck or something wrong as the driver side only blows cold while right side blows hot w/heater on. That is another issue I realize (and book/exclaimation mark is on climate display so it probably needs codes read) but it might be a good combo attack since the dash will most likely be off anyway.
Comments?
I appreciate your insight greatly!!
Doug
Dburgoyne is offline   Reply With Quote
Old 02-09-2007, 04:05 PM   #2 (permalink)
TerryS's Avatar
Gallery: 2
OOO, you're in trouble now. The O rings on your heater core inlet & outlet tubes are shot, and you need blend motor work. The ONLY good news is that you need to Totally dissassemble the entire dash to get at all the blend motors, and the heater core, so you better plan on doing the whole thing at once. Buy Lottery tickets.
Old 02-11-2007, 05:08 AM   #3 (permalink)
mcnabj's Avatar
yep its the heater core o rings. have fun.
mcnabj is offline   Reply With Quote
Old 02-16-2007, 11:51 PM   #4 (permalink)
Aftermarket security system installed
ikoinu's Avatar
Barr's stop leak might buy you some time with those rings, generally on rovers it's a necessity.
98 RR 4.0
ikoinu is offline   Reply With Quote
Old 02-18-2007, 09:35 PM   #5 (permalink)
I have a left hand drive 99 4.6 Rover and got some water on my passenger side a few days ago. The water was a bit oily. It was oily enough not to just wipe off but I could wash it off with water. Not sure if something I was carrying leaked a bit but the side was pretty soaked in today. I checked the AC drain today and it was clear so I am assuming it is the heater o-rings also.
My question is about the heater sensor that everyone say to replace at the same time. Today my temperature gauge on my dash cluster pegged out and the little red light came on along with the testbook on my HVAC unit. Would this be caused by that heater sensor or would that be another sensor?
If this helps with a bit more info, my heater was on when it was doing it. My engine was not overheating, it was just reading wrong.
Mattco is offline   Reply With Quote
Old 02-21-2007, 11:09 AM   #6 (permalink)
Default It helps ..
Shortcuts to O-Ring Replacement Procedure
The official O-ring replacement procedure outlined in the shop manual is to devote 12 hours of labor (by you or the dealer) to removing the entire dashboard and center console, disconnecting the air conditioning, disconnecting both airbags, and pulling the steering column. While this procedure is necessary when the entire heater core needs replacing, alert readers have found shortcuts which greatly ease the pain of the operation and avoid massive dismantling of the dash.
As the heater O-ring connection is under the right-hand side of the dash, it is a fairly inconvenient fix for RHD vehicles owing to the steering column and other stuff under the dash. For LHD vehicle owners, it is easier (see below) as there is only the glove box and transmission hump side panel to remove. Ron Beckett of Australia has supplied the following details on how to replace the O-rings in a RHD Australian 4.6, after he noticed a bit of leakage onto the carpet, apparently triggered by disturbing the fittings whilst replacing all the water hoses. We are also extremely grateful to David Sparkes in the UK for the initial advice, especially where to drill holes, and photos (not reproduced here) on how to remove the ducting in order to access the blend motors (another page in preparation!). Note that the basics of replacement don't change for a LHD car, it's just that you may have more access for your hands - which makes it easier.
An alternative method of accessing the O-rings is removing the dash -- this operation is described on the Dashboard Removal Page.
Once you have everything apart, Ron also highly recommends you replace the Core Temperature Sensor at the same time. The sensor clips onto the lower heater pipe and is very easy replace whilst you have the car apart. It is a common failure item and if you have the TestBook symbol appearing on the HEVAC display, followed by it having cleared at next start up, there is every chance the sensor has failed. It's not cheap (about US$30, A$50) but it's probably still worth doing. It probably also affects the operation of the air conditioning as it provides information about the water temperature to the HEVAC system - so it's better that it works properly.
O-Ring Location and Access
The O-rings are located on the right hand side and above the transmission hump - actually just above the RH footwell air vent. In fact, if the O-rings are leaking, you often find tell-tale white residue from the coolant in, or around, the vent - see photo below. To get access to the O-ring connection requires that you will have to remove the large lower fascia under the steering column (RHD vehicles), and the RH side panel on the centre console. Ideally, you need to remove the instrument panel as well to gain access to the upper end of the ducting. The workshop manual tells you to remove the complete fascia (dash) assembly - officially a 12 hour job but reduced to 6 hours (including removal and replacement) using the procedures described on the Dashboard Removal Page. Thus, the method to be described below is much quicker. A lot of this work is also required if you need to replace the distribution or blend flap motors (see blend motor replacement page) - another job which LR say requires removal of the fascia assembly.
Start by removing the RH side panel - see the page on Removal and Replacement of the Side Panels.
With the side cover off, you now have access to the lower air vent and duct. The outer vent outlet just pulls off. The inner vent outlet is retained by two screws, one of which also holds the air duct in place. Remove these two screws. Note the white residue on the heater matrix above the vent where the coolant has flowed down. Unfortunately, the residue on the vent itself had been cleaned off before the photo was taken.
Above: Pull off the outer vent and ... Above: Remove the two inner vent retaining screws.
The air duct which runs from the screen down to the floor is further retained by a screw hidden behind an inner panel. You have two options: (a) pull on the duct to break off the mounting lug or (b) drill a hole through the inner panel to access the screw. This hole will be covered when you refit the side finishing panel removed earlier. The photo below shows where to drill the hole to access the hidden screw.
Above: Drill a hole here to access the hidden screw behind... Above: Stay Tuned!
At this point, the access procedures diverge for the LHD and RHD vehicles - but this section deals with the additional access for RHD vehicles. In this case we need to release the top of the duct to allow it pivot out of the way at the bottom. (This will become clear when you do the job). To do this we have to remove the instrument panel. It may not be strictly necessary to do this but I didn't feel comfortable with flexing the lower heater duct out of the way to get to the O-ring heater connection screw.
So for RHD vehicle owners, we refer you to the instrument binnacle removal page - see Removal and Replacement of Instrument Panel
Return to Top
Removal of the Heater Ducts
Removal
After pulling out the instrument panel, you will now be able to access the top of the heater ducts. These ducts connect the heater to the upper outer dash vents and to the floor vents.
Referring to the pictures below, slide the intermediate joiner to the right to disconnect the inner duct from the outer duct. This will allow the inner duct to be separated from the heater and swung away at the lower end near the heater matrix. It will require quite some flexing of the duct to get it out of the way - but it can take it the flexing.
Above: Slide this intermediate joining piece right to.... Above: .... disconnect the inner and out ducts.
Optional Access Improvement Surgery
Kevin Potter of New Zealand found that after removing the instrument cluster and pushing forward the heater ducting as per the above instructions, it was advantageous to bore a hole in the inner right hand panel, using a hole saw (see picture below). This allowed him to get a long 250mm phillips head screwdriver (without handle) in to release the o-ring clamp (see below). Using this technique, he reports that removal and replacement was quite easy, saving quite a bit of time (total time including repair of broken fittings from previous morons 6 hours - should have been 3!!)
Kevin's innovative method for easing access to the screw securing the heater pipe clamp (see next step). Cutting a hole in the inner side panel also allows you to see what you are doing,, and does not significantly affect its structural integrity.
Removal and Replacing of the O-rings
Removal
Above: Pipe connector to heater matrix.
Below: The pipe clamp released. You can just make out the edge of the O-ring on the lower pipe.
Above: Another view of the heater pipe attachment. Note just-visible phillips head screw which has to be removed to release the pipe clamp (see below left). That blue item is the connector to the heater core temperature sensor which is clipped over the heater pipes and which often fails.
Below: Heater core temperature sensor mentioned above.
Abbreviated Procedure for Left-Hand Drive Models
Thomas Dirksen found a much faster way to replace the O-rings when coolant started leaking into the cabin of his US-spec 4.6 HSE, saving $1,000 in labor. He removed the glove box and was able to loosen the screw holding the O-rings by going through the glove box lock hole. This procedure took about 3 hours.
Thomas bought two O-rings from the dealer for $10. Then he removed the glove box and panels and the glove box lock. Looking inside the lock hole you can see the single screw that secures the O-rings. He used about 16" worth of 1/4" drive extensions, with a universal joint, to reach the philips screw. He secured the bit and the socket with 3M high strength adhesive so they would not fall off while trying to loosen the screw. Once the screw is loosened the heater pipes disconnected very easily and were very accessible where the glove box was removed.
To install the new parts, he cleaned the crust off the pipes where the coolant had been leaking, and lubed the O-rings with coolant. The philips screw was damaged during removal, so he replaced it with a hex drive machine bolt of the same thread pattern, complete with locking and flat washers. He used the 3M high strength adhesive to temporarily bond the new screw to a hex drive bit. He managed to insert the screw into the hole, and when it was sticking out on the other side by 1/8" he placed a drop of Loctite on the exposed threads. He pushed the O-ring fastening bracket on to the bolt and tightened the bolt down all the way. The leak was gone!!!
Simon Goode confirms the effectiveness of this technique. The only snag he struck was: "When trying to undo the screw I rounded it out and had to end up cutting a slot in it with a hacksaw blade to fit a blade head driver in. Then when I attempted to undo it the screw snapped. I then had to remove the pipes and plate to drill out the broken screw. That worked and it all went back together! I managed all this with only removing the parts described in your page. So just to let others know even when it does not all go to plan you do not need to remove all the dash!"
Lonn Howard also used this method: "I changed my matrix o-rings by passing the socket extension through the glove box lock hole.... the extension was guided as if by magic to the cap screw almost every time. (The dealer) had never tried it that way, preferring instead to go through the space vacated by the radio. A word to the wise... refill with water only to test your connection."
Footnote: The official Land Rover dealers may now be cottoning on to this faster procedure pioneered by Thomas. The local dealer recently replaced my heater core O-rings (April 2003) and I was only charged for about 4 hours of labor.
Parts Required:
2 heater core O-rings, part number STC 3262.
Tools Used
Above: The tools required for the job. Note the flexible bit-driver.
Below: I replaced the phillips head screw with a socket head cap screw cut to the right length, hence the need for the allen key drive bit.
More Information
Dash Removal Method: Jos Geuze removed his dash (fascia), which is the O-ring access method recommended in the shop manual. He found this is not as difficult an operation as previously thought, and has provided a full illustrated description on the dash removal page.
Andy Cunningham has a text-only description of David Allcock's approach for the UK-spec 4.0/4.6, with alternatives by David Sparkes, at this link.
Pascal
Pascaltissot is offline   Reply With Quote
Old 02-21-2007, 01:42 PM   #7 (permalink)
The above text was, of course, borrowed from Rangerovers.net. (http://rangerovers.net/repairdetails...html#shortcuts)
I'm sure Pascaltissot just forgot to credit it.
skippy3k is offline   Reply With Quote
Old 02-23-2007, 10:02 AM   #8 (permalink)
Default web site
Yes you are right it is , one thing that I cannot get to send you is the photographs ,no way to include them on the test ,but you can check on that web site o.k. sorry about omitting the source but I though it wood come out the complete article and it did not …sorry guys
Saludos cordiales,
Pascal..
Pascal
Old 02-23-2007, 01:47 PM   #9 (permalink)
No worries, Pascal.
  Land Rover Forums : Land Rover and Range Rover Forum > Land Rover Model Forums > Range Rover P38, Mk III and Range Rover Sport
SEO by vBSEO 3.3.2
