You can relatively easy add [SIZE="4"][URL=I post spam links in my responses since I'm a moron"[/SIZE]] -you will also need a harness that will allow install without cutting of the OEM wiring.
OEM Head unit is connected by a fiberoptic cable to OEM amp. U will need to hide OEM HU in the dash, and wire new HU to aftermarket amp, then into OEM speaker wiring.
Just for BT I used Parrot, which works just fine.
