» Site Navigation
» Model Specific
» Other Sites
03-09-2008, 12:31 PM
#1 (permalink )
Hood latch
The drivers side latch on my 1999 P38 broke. I can not open the hood now. Are there any tricks to open the hood???
Thanks
I understand your Jeep thing, That's why I drive a Range Rover
I got your Jeep thing, Now it hurts when I pee.
It's not a Jeep thing it's the real thing.
03-09-2008, 02:59 PM
#2 (permalink )
Sail; I thought you were up annapolis way? Did you move to canada?
03-09-2008, 05:47 PM
#3 (permalink )
move to canada
You must have me confused with someone else. I have always been here. I have had this handle the whole time I have been a member.
03-10-2008, 05:56 AM
#4 (permalink )
My mistake. Apologies. Good luck with the hood issue.
03-13-2008, 12:16 PM
#5 (permalink )
If any one have the solution it will be very important to publish it, All of us are in danger to have the same problem at any time
Thanks a lot
Pascal.
Pascal
03-30-2008, 02:43 PM
#6 (permalink )
I repaired the latch myself. I made a hook from an old wire coathanger. I pulled on the latch cable at the passenger side thus enabling the hood to release. The hood was frozen in the winter. When I pulled the latch from inside it broke the plastic clips that held the wire on to the latches. I replaced the latch on the driver side. It was around $24.00 I also replaced cables to both latches. They were around $45.00. The passenger side latch was too expensive for me to replace as it has the alarm attached and it is over $125.oo Please feel free to ask any questions
Joe
04-17-2008, 10:01 AM
#7 (permalink )
Hi yes, you change the cable, but how did you open it ¿??
Pascal
04-24-2008, 06:59 AM
#8 (permalink )
we made a hook with an old wire coathanger. I pulled the cable from behind the grille. It undid the latch and we could open the hood
04-24-2008, 07:19 AM
#9 (permalink )
Thanks a lot for your explanation, that means there is access thru the front grille until you get the latch with a hanger wire .Thanks .
Pascal
Pascal
04-27-2008, 08:18 PM
#10 (permalink )
we did not pull the latch. The cable is mounted under the rad cross member. We pulled on the cable and this undid the latch
Linear Mode
