Old 01-16-2007, 06:45 PM   #1 (permalink)
Default i am getting free cats converters
I just went to my dealer ship to day and thay ran my vin and it looks like i am getting new cat-converters for the rover. They told me that it is a outstanding recall and thay will do all the work for free i just need to set up a time to drop it off ( how cool is that )
mr mike is offline   Reply With Quote
Old 01-16-2007, 08:44 PM   #2 (permalink)
rqwilliamsjr's Avatar
what year range rover?
I love Range Rovers
1997 4.6 HSE Special Vehicles Concept
Borla Exhaust
HID headlight conversion
K40 built in radar detector
1989 RRC Country
Borla Exhaust
BFG All-terrains
Big Ass Rack in the back
H4 Conversion kit and bright lights!
rqwilliamsjr is offline   Reply With Quote
Old 01-16-2007, 10:18 PM   #3 (permalink)
Giver of Last Rights to Fallen Rovers
Default cats
Hello,
Any chance you can get your old cats? I need a few more sets before i can sell them for srap. I would pay 100 bucks a pair for factory cats.
Marty
270 576 7922
Drillbit is offline   Reply With Quote
Old 01-16-2007, 10:33 PM   #4 (permalink)
Rocky Mountain High
Funrover's Avatar
x2...my parents has a rattle to them!
Old 01-17-2007, 08:34 AM   #5 (permalink)
mcnabj's Avatar
Thats strange. I just did the same thing for my 97 4.0. The dealer is replacing the cats and all four o2 sensors for free! I mentioned that I had heard there was a recall on the cats and my dealer confirmed it. I am very happy with Land Rover for a change. Anyone with a p38 should look into this.
mcnabj is offline   Reply With Quote
Old 01-17-2007, 08:44 AM   #6 (permalink)
Rocky Mountain High
Funrover's Avatar
Thanks!!
Old 01-17-2007, 06:13 PM   #7 (permalink)
thay are doing the o2 sensors for free! thay did not say anything about that
how do i get them to throw them in to ???????????? ooo my rover is a 1996 4.0
Old 01-24-2007, 07:00 AM   #8 (permalink)
What years is the recall for?!?!?
Ken
Sunnyvale, CA
95 DI
02 P38A 4.6HSE
scubaman99 is offline   Reply With Quote
Old 01-24-2007, 12:29 PM   #9 (permalink)
98RRover's Avatar
is this only for the 4.0;s?
98 4.6 HSE Customized to the season
98RRover is offline   Reply With Quote
Old 01-24-2007, 01:14 PM   #10 (permalink)
mcnabj's Avatar
I would imagine that since the 4.0's and 4.6's have the same cats that the recall is for both. Don't quote me though.
Old 02-02-2007, 02:43 PM   #11 (permalink)
What years????
Ken
Sunnyvale, CA
95 DI
02 P38A 4.6HSE
Old 02-02-2007, 02:59 PM   #12 (permalink)
Elemental's Avatar
No: D236
Ref:Issue: 1
Date: 01/04/02
RECALL
Catalyst Inspection and Replacement
AFFECTED VEHICLE RANGE:
Range Rover (LP) SA302054 to VA350101 (Phase I)
VA350102 to VA376578 (Phase II)
SITUATION:
CATALYST DEGRADATION CAN LEAD TO NOISE AND MIL ILLUMINATION
A defect that relates to vehicle emissions exists on 1995 through 1997 model year Range Rover 4.0/4.6 vehicles imported by Land Rover North America, Inc.
Range Rover customers may experience a rattle from the underside of the vehicle. In some instances they may also experience a MIL illumination. The symptoms result from loose catalyst "bricks" within the exhaust system catalysts.
RESOLUTION:
INSPECT CATALYST PIPE MARKINGS AND REPLACE IF INDICATED
Utilizing the inspection parameters in this TIB, determine if the vehicle catalysts are within the affected build range. Both the exhaust down pipe/catalyst assemblies and the oxygen sensors must be replaced on vehicles equipped with the original design catalyst that is prone to deterioration.
NOTE: Some vehicles within the affected VIN range may have had repairs under normal warranty provisions. These vehicles may already have correct updated replacement catalyst assemblies.
PARTS INFORMATION:
NOTE: Parts numbers with a "K" suffix are intended for Recall repairs only. All parts in the Recall parts listing must be used for each repaired vehicle. Any retailer found to have abused this stipulation will be subject to audit. Parts orders will be monitored to ensure appropriate parts usage.
WCD000860K Down pipe assembly Qty 1
FX110047L Flange nut Qty10
ESR3260 Gasket Qty 2
NV108041L Nut Qty2
ANR3643 Set screw Qty 2
ERR1834K Oxygen sensor Qty 4 Up to VA350101
AMR6244K Oxygen sensor Qty 4 VA350102 - VA376578
LRN0002LABEL Recall Label Qty 1 Note order quantity 1=100 labels
WARRANTY CLAIMS:
D236 (Option 1) Time 0.20 hrs.
Inspect down pipe/catalyst assembly
D236 (Option 2) Time 1.50 hrs
Inspect down pipe/catalyst and replace along with oxygen sensors
Normal warranty policy and procedures apply.
Material allowance is included in labor operation.
REPAIR PROCEDURE
INSPECT CATALYST FOR DATE CODE
1. Raise the vehicle on a lift.
WARNING: Catalysts can be extremely hot even after a short period of operation. Verify that the catalyst is cool before starting work on the system.
NOTE: The date code is stamped directly on the side of the catalytic converter or stamped on a plate attached to the converter.
2. Determine if the catalyst requires replacement as follows:
^ Verify the part number of the catalytic converter is either ESR4219 or ESR413O
^ Refer to Figure 1 and determine the date code on BOTH catalysts.
NOTE: Catalyst assemblies may have been replaced as a warranty repair so the vehicle VIN may not be an accurate guide for replacement requirements.
It is also possible for one catalyst in a system to be within the date range of this Recall while the other is outside the range.
If either catalyst has a date code before "30-98" (Week 30 in 1998) the down pipe/catalyst assembly must be replaced.
3. If EITHER catalyst date code is ON or BEFORE the date code of "29-98," go to "Replace Pipe/Catalyst Assembly and Oxygen Sensors" and perform the Recall repair.
4. If BOTH catalyst date codes are ON or AFTER the cut-off date code "30-98," claim D236 (Option 1) for the inspection and go to "Install Campaign Label" to place label on vehicle. No repair action is required.
Old 04-01-2007, 01:41 PM   #13 (permalink)
Hi Elemental
Could you maybe send that letter you posted about the recall to my e-mail I cant get the print to work and would like a copy for local dealer. have them check my RR too I have very limited service records from seller.
Thanks Mary
packgirl@charter.net
packgirl is offline   Reply With Quote
