Old 04-05-2006, 07:37 PM   #1 (permalink)
Rovering and Lovin' It
ZAD329's Avatar
Exclamation Idle Problems!!!
I have terrible idle problems in my 2001 RR 4.6HSE. The stealership replaced the mass air flow sensor with no improvement. I ran a fuel injector cleaner through the fuel and that didn't help either. What to do?!
'01 Range Rover 4.6 HSE
'97 Mercedes-Benz E320 - SOLD
Zach Davis, Realtor and Auctioneer
Kirkpatrick & Company
CENTRAL KENTUCKY EQUINE REAL ESTATE SALES
(859)-576-8195
www.ZachDavisProperties.com
ZAD329 is offline   Reply With Quote
Old 04-06-2006, 06:13 AM   #2 (permalink)
02RhinoRange's Avatar
Location: Nashville,TN and Chattanooga/Dayton/Knoxville for play....
I brought it to a local mechanic who cleaned out the throttle body - he said it was full of carbon buildup- and that fixed the problem.
mine did it to, cleaned the idle air stepper motor and no problems since.
http://www.rangerovers.net/newrremedies.htm#stepper
~Both from this RangeRovers.net thread
If you don't already know, RangeRovers.net is a supurb resource of information on your Rangie, there's technical "member submitted" articles for repairs and solutions, and there's also a great forum that the above quotes and threads came from. It also has a great search function, give that a go.
Hopefully you only need a throttle body cleaned and you'll be good to go.
'02 Range Rover Rhino ed.
Warn XD9000 w/ factory winch tray
RockRover diff guard, RockRover sliders
Safety Devices roof rack
255/70R16 Pirelli Scorpion ATs on 16" DII alloys
255/55R18 Nitto 420S on 18" Proline wheels
'95 RRC LWB County
Coil conversion w/ OME shocks, AB springs
02RhinoRange is offline   Reply With Quote
Old 04-06-2006, 08:40 AM   #3 (permalink)
Can you describe in more detail what yor idle is doing, when, what octane gas you are using and any tune related maintance you have done recently???
Old 04-06-2006, 04:14 PM   #4 (permalink)
ZAD329's Avatar
Hey Mike --- the dealer just did the 90k factory service (which is a huge service). The problems arise when I stop at a red light or whenever I am at idle (under 1000RPM). I always put premium gas in her. When at park, I'll rev the engine up to just over 1000RPM and the vibration is gone.
(859)-576-8195
Old 04-07-2006, 07:27 AM   #5 (permalink)
Do you have a check engine light on, how does it run when driving, is it smooth, does it pull hard under power? Does it happen when the engine is hot or cold?
Just out of curiosity, open your hood and look at the under hood liner, does it have any new tears or wear marks on the material? The reason I am asking is I am wondering if your have broken both of your engine mounts, if so the engine will feel rough and it will lift up and rub on the under hood insulation pad.
Old 04-07-2006, 12:04 PM   #6 (permalink)
Default posible causes.
It looks more like a spark or injection problem ,but if you had the injector cleaned up and no change occurred it is wise to look the spark plugs, a change would be advisable(original one are required ) . If problem persist buy a canister of carb cleaner and clean the stepper motor entry (remember to write dawn number of turns when taking of the security plug off, and unscrew the inner screw ) or you would have to take it to a dealer to have it calibrated again in between 15 and 30 steps .star here and then we will go on other possible causes .
Saludos
Pascal
Pascal
Pascaltissot is offline   Reply With Quote
