Intermittent Low Frequency Hum from Rear
Help! I have a strange humming noise coming from the rear of my recently purchased 2003 RR. The best way I can explain it is that it sounds like a foghorn or a bass speaker that resonates inside the cabin and appears to come up through the floor board near the back passenger wheel area. It can get pretty loud at times. The weird thing is that is only happens intermittently at around 30 and 40mph. I've been able to produce the sound by slowly accelerating and keeping the speed somewhat constant. If I can keep the same speed I hear it for a longer period. It is more pronounced at 40mph, especially after being at 45 or higher, then dropping gear and going easy on the accelerator down to 40mph. Also seemed louder uphill.
It sounds a little similar to other posts I have read, but there really is no significant vibration. The car drives perfectly fine otherwise, and at other speeds. I read up on wheel bearings, differentials etc, but none of the symptoms exactly match. No squeals, rattles, grinding, knocks, etc. I have not had a chance to look at the tach when it happens, but will be doing so tomorrow to see if there is any correlation.
The tires are Hankook's on 19" rims (they came with the car). Has anyone ever comes across a similar situation? Could this just be a bad tire set up or signs of a more serious problem? Any help would be greatly appreciated.
Thanks!
03 Range Rover HSE Adriatic Blue
Ex - 04 Discovery SE
Ex - 99 Discovery II
