Old 01-15-2005, 04:12 AM   #1 (permalink)
Question Key won't work even with new battery
One of my keys won't work anymore ( the keyless entry ) even with new batteries. 1998 4.6HSE
Any suggestions?
mafpolo is offline   Reply With Quote
Old 01-15-2005, 07:23 AM   #2 (permalink)
Try cleaning the contacts, if that doesn't work, go to ebay and buy a new one, yours is dead, which is not unusual, they fail pretty easily.
Mike J.
Old 01-16-2005, 05:03 AM   #3 (permalink)
Default After I buy the new one...?
How do I program it for my vehicle?
Old 01-17-2005, 03:58 AM   #4 (permalink)
Default How do I program it for my vehicle?
Unlock car using good key then place key to be programed in drivers door press lock button and keeping button pressed lock door by turning the key the key is now programed
MG-FRANCE is offline   Reply With Quote
Old 01-18-2005, 06:05 AM   #5 (permalink)
troverman's Avatar
There should be a "key synchronization" procedure in the owner's manual--On mine you take the keyless which won't work (the one you put the new battery in) and be outside the car with the doors unlocked. Press the "lock" button on the keyless then flip the key out and lock the driver's door (turn key toward rear or the car) The key should now be programmed. You can also do it the other way, start with locked vehicle, press unlock on keyless then unlock driver's door with key.
As far as I know, don't buy a keyless fob off ebay for a 4.0 / 4.6 RR. They cannot be reprogrammed unless you have the BeCM from the donor ivehicle as well. (Someone could buy a key for $50 off ebay, copy the VIN off a 2002 HSE at the mall, follow that RR home so they know where they live, have the ebay key programmed to that VIN, and steal they car easily)
Current:
2005 Land Rover LR3 V8 SE
Also current:
1995 Mercedes-Benz E320 Wagon
2002 Volkswagen Eurovan GLS
1996 Ford Explorer LTD 2WD
1982 Volvo 240 GL Diesel
Previous Rover:
1995 Range Rover 4.0SE
