Old 05-07-2008, 04:51 AM   #1 (permalink)
Default Locking Gas Cap - LR Response
I received a telephone call from Land Rover about my quest for a locking gas cap. I was told by the person that called that:
Supposedly the door to my filler door should not open if the car doors are locked. When I explained that all you had to do was lightly tap the door it popped open - they indicated that it was defective and should be taken to the dealer for repair.
But then they continued on by saying "you should NOT be able to open the filler door unless the doors are unlocked and the key is IN the IGNITION."
When I told them they couldn't be serious - that in order to open the filler door I had to leave the keys in the ignition??? That doesn't even begin to make any sense what so ever.
RedRaider is offline   Reply With Quote
Old 05-20-2008, 09:59 AM   #2 (permalink)
I received another call from LR since I questioned the logic behind the requirement to have the key in the ignition to unlock the filler door. No surprise they were wrong.
But what I was told that all other LR products have either filler doors that lock and/or after market gas caps can be purchased... the one exception RR Sports.
When asked if LR was going to work with an after market vendor to provide specs for a locking cap.. the answer was basically NO.
Old 06-12-2008, 08:57 PM   #3 (permalink)
Jagfixer's Avatar
My Disco 1 and my 4.6 Range have a cap that screws on. These caps are actually a GM type cap and a locking cap is available in vented and non-vented that can be used on the D1 and the P38 Range Rovers. I bought mine at a real parts house not AZ or the likes. I think I paid about $15 for the cap.
Larry K.
96 4.0 Discovery 1 ( 9 yrs )
96 4.6 HSE Range (3 yrs )
87 RRC ( 5 yrs. )
Jagfixer is offline   Reply With Quote
P38 ..Non-Starter!! Fozzy Range Rover P38, Mk III and Range Rover Sport 25 04-12-2006 03:50 AM
Alarm Ecu Central Locking dacrts Discovery Series I 1 12-06-2005 03:03 AM
99 4.6 is superlocked and won't reset Spring Range Rover P38, Mk III and Range Rover Sport 9 12-05-2005 04:46 PM
Central locking system bad? superpowerdave Discovery Series II 2 10-29-2005 09:14 AM
tailgate central locking simon285 Range Rover Classic 1 10-20-2004 09:55 PM
