Links
Old 05-06-2008, 02:34 PM   #1 (permalink)
Default Massive coolant leak issue
Have a 2000 RR 4.0. Two days ago it overheated while driving. I shut it down ASAP and let it cool. Coolant level was low, so new was put in. Drove home with no problems. Next morning, however, massive amounts of coolant covered the garage floor. There appears to be a leak, but I can't find it. It's dripping down to the oil pan. I'm hoping that I didn't do some major damage. Coolant doesn't leak when engine is off and cold. Run it for two minutes, however, and the drip starts again. Any ideas?
D. Hammack is offline   Reply With Quote
Old 05-20-2008, 07:21 PM   #2 (permalink)
Sailcnc's Avatar
you warped the head and the head gasket is leaking. I had mine done two years ago. I am not sure if it was dome incorrectly or the gasket failed. I am in the process of re doing it now. The engine is completly apart and I will take the heads in to have them checked out. It was 2k last time I had it done. I do not want to put out that cash if I do not have to.
I understand your Jeep thing, That's why I drive a Range Rover
I got your Jeep thing, Now it hurts when I pee.
It's not a Jeep thing it's the real thing.
Sailcnc is online now   Reply With Quote
Cylinder#6 Misfire & Coolant Leak tskim2024 Discovery Series II 3 02-09-2008 09:07 AM
Strange coolant leak..!! DiscoDoggII Discovery Series II 9 10-29-2007 03:46 PM
Small Coolant leak...Blow Head Gasket? maverick544 Discovery Series II 9 09-22-2007 08:27 AM
coolant leak help scotth Discovery Series II 3 09-02-2007 10:56 PM
Yet Another Coolant Leak drprofessional Range Rover Classic 4 03-29-2007 01:46 PM
