» Sponsors
» Sponsors
Old 10-05-2004, 04:42 PM   #1 (permalink)
Angry My radio doesn't work?
I just bought my first Range Rover, it's a 1997 Range Rover 4.0 SE, and I can't get the radio to come on. The closest dealer is about an hour away from me and I don't have time to take it in, so I am trying to figure it out on my own. I know it is in the anti theft mode, and I got the code for getting it back on, but to no avail. Can anyone tell me the proper sequence entering the code? I turned the key one click, have the power on to the radio, let it sit for one hour, then I get lost....do i enter the code, turn the car on then the code, turn the car off then the code....I'm lost and need help. Thanks, Nate
1997 RANGE ROVER 4.0SE
golfpro is offline   Reply With Quote
Old 10-06-2004, 03:13 AM   #2 (permalink)
Default A bit late
Hello,
I hope you manage to solve the problem.
I hadthe same story. The radio did not show "CODE". Actually according to the dealer you must wait some times few days beforethe radio show "CODE" and is ready to accept a code.
Here is the instruction from LR.
Range Russian is offline   Reply With Quote
Old 10-06-2004, 09:36 AM   #3 (permalink)
troverman's Avatar
I would pull out the radio from the dash first. Pop the plastic front panel off, then use small screwdrivers to poke the small holes on top of the radio. Pull the radio straight out. There is a "reset" button somewhere on the radio housing (maybe front bottom?) Push it with the screwdriver again. You can have the radio on or off when you do this. Then put it back in the slot, put the cover on, ect. Turn the key to the radio power position, turn the radio on so it says code, and punch in your 4 digits. The radio within like a second should switch to the tuner mode and be fine. If not, leave the radio on so it says code or wait, whatever, then leave the key in the on (first) position for an hour or so, and try again. (No reset this time) If not, call the dealer.
Current:
2005 Land Rover LR3 V8 SE w/ factory winch
Also current:
1995 Mercedes-Benz E320 Wagon
2002 Volkswagen Eurovan GLS
1996 Ford Explorer LTD 2WD
Previous Rovers:
1995 Range Rover 4.0SE (see avatar, driving during local flood)
Old 10-06-2004, 11:17 AM   #4 (permalink)
glenncof's Avatar
golfpro,
mine is 1991 but 1) turn on ignition, 2) turn on radio, 3) see "Code" on radio display, 4) carefully punch in code, 5) hear beep that code is accepted. Ready to roll. If you make error turn off radio and turn on again. (no waiting)
Carefully = make sure the button is fully pressed but not twice
Reset needed every time power lost. I have had this occure with very weak battery at start-up also.
I had a time where it would not accept code. I just kept trying at stop lights and it kicked in after 100 times. Now works fine. (?????)
glenncof is offline   Reply With Quote
Old 12-17-2008, 06:43 PM   #5 (permalink)
Default 97 LRRR Radio Code
I know this is an old post but I have a similar situation.
My problem is that I can't get the screen to ask for 'Code In'.
I disconnected the neg terminal of the battery (as suggested by the dealer) and after a few minutes reconnected. Turned on radio to enter the Code but all I get is a lit screen that is blank. If I press the On and BND buttons at the same time I can get the radio/cd to play for 2 minutes before it shuts off with the screen still lit and blank. I even pulled and disconnected the radio and reinstalled but same results.
Any suggestions/ideas on how to access the 'Code In' screen would be sooooo helpful so I can reactivate the radio/cd player. This is the stock radio that came with the car. I really miss it.
Thanks.
vjm530 is offline   Reply With Quote
Old 12-19-2008, 03:12 PM   #6 (permalink)
Default LCD Replacement
I got my radio to finally take the Code and it's working fine. But . . . the radio screen is lit but no info so I assume the LCD is burned out. Does anyone know if this is replaceable and where/how to start this repair without sending the radio away for $200? Thanks.
Old 01-10-2009, 08:41 AM   #7 (permalink)
4.6HSE
Push only the band button for a minimum of 4 seconds and let off. This will reset your radio so it will accept the code
Murrykiki is offline   Reply With Quote
Old 01-10-2009, 08:44 AM   #8 (permalink)
4.6HSE
I have a 97 HSE. Same problem. Push the band button for a minimum of 4 seconds and let off. It will reset your radio. The cd player will work about a minute later
