try removing the lower tail gate cover from inside the vehicle you will find
two latches inside one for the upper (glass) and one for the tail gate,
you should be able to manually trigger them by hand. I did this on a range rover
of the same year in a junkyard and open it right up!
Hope this helps.. try checking the wiring harness while your there, it may have wiggled loose.
