#16 (permalink) | |
The engine should run at idle with the AFM disconected.The ECU only looks for feedback after approx 550 rpm then it should go out of range and the engine cut out.not familliar with your LPG system,most dont rely on the AFM,only the lambda.So with the AFM disconected from the plenum the only thing that could happen is a loud bang.Try removing the fuse for the petrol pump,then running on gas.Killing 2 birds with 1 stone,fuse ensures your not supplying both LPG and petrol at the same time.If it runs then it looks like the AFM. Or substitute The AFM for a known good 1 |
