Old 06-04-2008, 01:23 PM   #1 (permalink)
Default P38 engine crack(????)
Hi there to all,
I am new to this forum as I recently decided to buy a Range Rover P38 4.6 HSE (1996). The car appeared to be in excellent hands and during the testing period did not came up with any fault.
I bought this car in Athens Greece and I moved to Heraklion Crete.
Anyway suddenly the temperature was rising and I went to the authorised service in Heraklion. They changed the thermostat and a valve (not sure though if they used an original or OEM product...) and for about 10-15 days it seemed all to be OK.
The temp. started to rise again, and the guys in the srevce started without even looking to the car to be a little more than eager to change the engine block...
It was obvious that their intentions were more than fixing the car.
I know that the specific model tends to have a problem with temperature yet I think that is more likely to be the gaskets or the sealers than a crack to the block.
Please if you have experience or similar cases with cracks or leaks from the gasket please share or advise.
I am little in the corner as I have recently moved, I do not know where to buy or where to service appart from these "authorised" cheats!
Plus if ant member knows where can I contact LR and possibly import from tha UK a new engine block I will do this rather than paying the ransom to them...
alexakis is offline   Reply With Quote
The Pushrod Engine Finally Gets its Due polar General Land Rover Discussion 0 05-25-2008 09:08 PM
Any body doing electric hybrid in a LandRover? Adam in NYC USA Hybrid 54 12-23-2006 10:39 PM
P38 ..Non-Starter!! Fozzy Range Rover P38, Mk III and Range Rover Sport 25 04-12-2006 03:50 AM
Custom fabrication people.. I have a pair of turbos 02disco2 Discovery Series II 9 01-24-2006 07:53 AM
99 4.6 is superlocked and won't reset Spring Range Rover P38, Mk III and Range Rover Sport 9 12-05-2005 04:46 PM
